What kind of fuse controls turn signal indicator on drivers side in 2011 Equinox
This is a discussion on What kind of fuse controls turn signal indicator on drivers side in 2011 Equinox within the 2010+ Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
What kind of fuse is used to control the driver's side turn signal indicator and brake light? It makes a ...
Old 10-18-2013, 09:46 PM   #1 (permalink)
beschaus is on a distinguished road
Default What kind of fuse controls turn signal indicator on drivers side in 2011 Equinox
What kind of fuse is used to control the driver's side turn signal indicator and brake light? It makes a fast-clicking noise when I use the left indicator and the indicator itself doesn't work. The light itself works when I use remote door lock to unlock/lock door, so don't think its issue with the light.
beschaus is offline   Reply With Quote
Old 10-19-2013, 01:42 AM   #2 (permalink)
Normally when you have a fast click with a turn signal it is a indicator that one of the bulbs are burned out. I would check the ambient light in the front head light as well as the lights in the tail light.
Old 02-24-2014, 12:57 PM   #3 (permalink)
Bicdaddy is on a distinguished road
There is a turn signal relay. It may need to be replaced... it's probably one of the more expensive relays in the vehicle.
Bicdaddy is offline   Reply With Quote
What kind of oil are you guys using? dietz4ibanez 2010+ Equinox Maintenance 79 04-27-2016 01:48 AM
Not working drivers dore. oleg1981 The Official "How To:" Section 3 07-13-2013 12:57 AM
Turn your clocks back... dietz4ibanez The Lounge 15 11-14-2011 12:20 PM
Tables Turn: Deputies and movers show up at bank to seize property for homeowner dietz4ibanez The Lounge 5 09-13-2011 08:39 PM
Where's the fuse boxes? Lenn 05-09 Equinox General Forum 9 05-13-2011 10:14 PM
