Starting problems, gas smell, shifting issues..
This is a discussion on Starting problems, gas smell, shifting issues.. within the 2010+ Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
I have a 2005 Chevy Equinox. Just had the fuel pump replaced as the car started having starting problems. Now ...
Old 04-29-2011, 08:23 PM   #1 (permalink)
Helene74 is on a distinguished road
Default Starting problems, gas smell, shifting issues..
I have a 2005 Chevy Equinox. Just had the fuel pump replaced as the car started having starting problems. Now it is starting to have the same symptoms again after replacing the pump. The fuel mileage is also even worse than it was...getting about 100 miles on half a tank. The problems are not consistent. Sometimes I go to start the car and it turns over and starts but dies. Thereafter it just "clicks". Rolled it backwards in neutral and it started up again. Sometimes there is a strong gas smell. It is also having some shifting problems/transmission slipping--but also not consistent. Mainly in low gears and going uphill. It is not all the time.
No apparent oil or transmission leaks. Anyone have any ideas? Oxygen sensor possible? Thanks for your time.
Helene74 is offline   Reply With Quote
Old 04-29-2011, 11:01 PM   #2 (permalink)
This may sound weird but I had a similar issue with a car I had in college. It ended up being the heater core leaked onto the computer and.shorted it out. I replaced many fuel pumps and sensors before changing the computer.
Old 04-29-2011, 11:40 PM   #3 (permalink)
Thanks for the message. Do you know the approx cost of such a thing? Did you have transmission problems from this as well?
Old 05-01-2011, 12:26 AM   #4 (permalink)
No tranny problems. And it was on a escort. I was able to get the computer cheap at a junk yard.
Old 08-06-2011, 04:37 PM   #5 (permalink)
fist of all i would change oil in Transmition. i changed it and its not that hard as it seems. my shifting is much better after that. i used Mobile JW3309 oil! as we have AISIN AF33 gear box that uses only that oil that meets JW3309 specification.
06 NOX
Old 08-21-2011, 04:50 PM   #6 (permalink)
Chevynox2005's Avatar
Chevynox2005 is on a distinguished road
I new some help guys- my no is almost at 150k and need the trans fluid changed. Took it to a firestone here and they said I don't have a dipstick for the fluid therefor they can't change it. Is this really happening? How do you guys get it changed?!
Chevynox2005 is offline   Reply With Quote
Old 08-21-2011, 05:32 PM   #7 (permalink)
I would take it to the dealer to have them change it... I think this also is the issue with the newer Acadia's and you simply have to replace the fluid with how much you drain out..
Old 03-30-2012, 03:05 AM   #8 (permalink)
stevemartin is on a distinguished road
This equinox and other stuff in which those are good
stevemartin is offline   Reply With Quote
Old 03-30-2012, 03:07 AM   #9 (permalink)
Hey dude those fuel pumps are great and good enough
Old 03-30-2012, 11:26 PM   #10 (permalink)
just so it. hope it will help to some one! there is a dipstick on nox transmition! it is very small and is accesable only from under the car.
06 NOX
Old 04-19-2012, 07:03 PM   #11 (permalink)
Nice Sketch.
Chevy Silverado Parts
Old 04-19-2012, 09:39 PM   #12 (permalink)
i will change oil in gear box this weekend.
to all that wants to change oil remember USE ONLY JWS 3309 oil!
06 NOX
Old 05-21-2012, 09:56 PM   #13 (permalink)
briando is on a distinguished road
check out the BG products for your chevy. they're solvent based which i know isnt supposed to be great for seals, but it does help i swear with the gas mileage, knocking, and general cleanliness of the engine.
briando is offline   Reply With Quote
Old 05-22-2012, 08:25 AM   #14 (permalink)
Bit Odd. You're not getting a check engine light?
2011 equinox stalling issues? Low4x4 2010+ Equinox General Forum 138 04-16-2016 02:04 AM
Is anyone having problems with their 2011? DeeDee1202 2010+ Equinox General Forum 9 01-04-2016 11:26 AM
2011 Equinox problems since purchase equiowner 2010+ Equinox General Forum 4 08-07-2011 04:34 AM
problem with starting point on navigation cyndi516 The Official "How To:" Section 2 04-16-2011 10:41 PM
