Non-Starting Condition
This is a discussion on Non-Starting Condition within the 2010+ Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
I got a 2010 GMC terrain AWD 2.4L which has a recurrent non-starting condition. Previously, I replaced the starter and ...
Old 05-28-2017, 03:50 PM   #1 (permalink)
tk3000 is on a distinguished road
Default Non-Starting Condition
I got a 2010 GMC terrain AWD 2.4L which has a recurrent non-starting condition. Previously, I replaced the starter and it seemed to take care of the problem; but then the non-starting condition is back is full swing: there is no sign of life coming from the starter besides what seems a click from a relay from the engine compartment
Took the new starter to a local autozone in order to check it and it passed all the tests.
Battery is new, and has been checked under load (load tester) and its cca checked ok too.
Checked the cables going from the battery to the starter for resistance. Obtained 2 ohms from battery terminals to starter terminals. Obtained about 3 ohms from battery negative terminal to spot where starter seats. The resistance seems pretty low so the cable should not be a problem.
There is also a check engine light. Readings were of values like $07E8 (which may be a misfire condition that could be the result of many failled starting attempts). Another code obtained was P15A1 which seems to be related to Fuel Economy Mode Switch Performance and not related to the non-starting condition of mine.
I swapped the starter relays with the fog light in the engine compartment for no avail. It seems that the culprit may be the neutral/parking switch. Also, I was trying to c heck whether or not there is signal going to the starter solenoid to engage it but I can not find a type of connector (only have crocodile clips) that will fit into the connector in the starter. But I suspect that there will be no signal going to the starter solenoid since the starter itself tested ok what brings me back to the neutral/parking switch or maybe something else.
Any insights into this conundrum would be appreciated.
tk3000 is offline   Reply With Quote
Help, louds noise random when starting Strongheart 05-09 Equinox Maintenance 10 09-20-2016 07:33 PM
starting problems dan112 2010+ Equinox Maintenance 4 09-25-2015 11:09 PM
2008 LS - trouble starting, etc. crj123082 05-09 Equinox General Forum 3 08-01-2015 08:43 AM
Aftermarket Keyless Starting? bigbillsd 2010+ Equinox General Forum 3 07-29-2014 08:54 PM
problem with starting point on navigation cyndi516 The Official "How To:" Section 2 04-16-2011 10:41 PM
