Equinox idle problems
This is a discussion on Equinox idle problems within the 2010+ Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
Ok, i have a 2012 Equinox has the following issues. Check engine light Service stabilitrack Reduced engine power. ( failsafe ...
Old 11-16-2017, 10:08 AM   #1 (permalink)
Caslau02 is on a distinguished road
Default Equinox idle problems
Check engine light
Reduced engine power. ( failsafe mode)
Ran the ODT scan tool and pulled codes
P0016 crank shaft pos sensor
P0089 fuel rail pres. Sensor
P0228 throttle/accellorator pos sensor
P0191 fuel pressure performance
When all the trouble started the engine would just want to die as you came to a stop in traffic and ran rough there after.
The problem would reset if you turned the key to off and then back on.
I replaced the crankshaft pos sensor
And the accelorator pedal
Cleared faults
Ran a fuel pressure check but the car would not run long enough for sufficient diagnostics.
I also cleaned the throttle body and inspected all electrical connections on the front of the car related to the fuel system.
The car does not even start not.
I suspect a fuel pump
I am at a loss, money is key here because we really dont have any.
Any help would be greatly apretiated
Caslau02 is offline   Reply With Quote
Rough Idle on 2011 Equinox Newtodanox 2010+ Equinox General Forum 2 01-31-2017 11:09 AM
05 Equinox problems Chrisb 05-09 Equinox General Forum 1 04-27-2016 02:58 PM
2013 Equinox 4 Cylinder Rough Idle karpetcm 2010+ Equinox General Forum 3 02-27-2016 01:22 PM
Brand new issue - rough idle and stall after driving - 05 Equinox beigmatt 05-09 Equinox General Forum 4 09-26-2015 11:18 PM
06 equinox rough idle at startup only [email protected] 05-09 Equinox General Forum 5 09-10-2012 03:45 PM
