Dull thud at idle coming from flimsy plastic item near throttle
This is a discussion on Dull thud at idle coming from flimsy plastic item near throttle within the 2010+ Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
I just removed the plastic engine cover on my 2012 3.0 V6 to pinpoint the dull tapping thud. I narrowed ...
Old 11-29-2016, 08:14 PM   #1 (permalink)
nichelson1 is on a distinguished road
Default Dull thud at idle coming from flimsy plastic item near throttle
I narrowed it down to a flimsy plastic component behind the front of engine factory plastic catch can.
This part has what looks like a 5/16 or so plastic vacume hose going to it.
I can change the severity of the tap by wiggling this item.
It is between the firewall & intake.
I thought the high pressure fuel pump was a hard metal item securely bolted to the engine.
This is a wigglable plastic part that is tapping at idle.
Any experts out there?
nichelson1 is offline   Reply With Quote
Old 11-29-2016, 08:52 PM   #2 (permalink)
I just took a few pictures of this part & have a piece of masking tape with a red dot on the part.
I will try to do photos.
Old 11-29-2016, 08:54 PM   #3 (permalink)
The closeup photos are blurry because I had to hold camera too close to get a view around other parts.
Old 12-02-2016, 09:02 PM   #4 (permalink)
SOLVED TAPPING NOISE.
Bought Vacume canister purge valve on Ebay for $30. (Dorman) & installed it in 10 minutes.
Tapping noise gone !!!!!!
Located behind throttle behind where air filter hose connects.
Remove engine cover.
Remove duct & oil vapor plastic jug between air filter & engine
1 10MM. bolt & 1 wire plug & 1 plastic vapor line.
Remove bolt with deep #10 socket 1/4" drive rachet & short extension.
Fish it out between fender & engine to make it easier to remove vapor line & wiring plug.
Quick & easy & no more ticking.
Throttle Body Cleaning.... MyEquioxblah 05-09 Equinox Maintenance 3 03-07-2017 07:36 PM
PLASTIC detailing TEL Detailing Tips and Tricks 5 07-12-2015 11:07 PM
Cleaning The Throttle Body?? bsr2002 05-09 Equinox Maintenance 3 05-23-2015 02:07 PM
2013 Equinox Radio display not coming on rtunas Audio & Electronics 0 06-15-2014 04:02 PM
UPDATED 2/28/11 Bad Ass new look for the site. Coming Soon. Shaggy 2010+ Equinox General Forum 17 03-01-2011 09:01 AM
