-   -   2015 Equinox Coolant Change (http://www.chevyequinoxforum.com/f5/2015-equinox-coolant-change-3115/)
rvseverson 09-12-2020 08:33 AM
I was going to do the 60 month/150K coolant change but haven't found any good information on how to accomplish this. The Haynes manual is useless. Says to drain the radiator & reserve tank and refill. Well you only get 3 of the 8.2 quarts out. The rest is stuck in the block behind the thermostat & in the heater core. I've found some references to a block drain plug near the water pump but the information is elusive. An extensive Google search and nothing useful. Then how about the heater core? Thanks
TARDIS B 12-31-2020 07:41 PM
Yes, not much information about this. I've just seen to drain the lower hose and refill. I guess doing this annually would do the job. Mine is also a 2015 and due for coolant change but finding information is next to impossible.
christian.wood 01-15-2021 05:40 AM
There's a drain plug on your water pump. Take off your overflow reservoir cap, open your petcock, and take the plug out of the water pump.
Sent from my SM-G975U using Tapatalk
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
