-   -   2013 equinox outside temp monitor (http://www.chevyequinoxforum.com/f5/2013-equinox-outside-temp-monitor-1168/)
tomas161 06-24-2014 04:00 PM
Since the day I got the equinox, this outside temp monitor did not function properly. I mentioned it once while having service, but was told it would be ok. Next time I made a specific apt to have it checked, and same thing, it will adjust automatically, etc... It has not. It is not a big thing, but it should be working. I had a 2002 olds van for 12 years and the outside display was always working, never a problem.. just a bit irritating. No complaints on the total vehicle or performance.
jsfb6pts 06-25-2014 06:45 AM
I had a 2011 ,never had a problem .I now have a 2014 no issues with that either .
mikeCsix 05-17-2015 01:23 PM
The outside temp monitor is located on the passenger side of the vehicle, just in front of the radiator and behind the bumper it is mounted on a bracket to sample air prior to the radiator. It has a weather proof connector, if the sensor isn't functioning, either there is a broken wire in the wiring harness, the sensor has failed or the connection is only partially made. Since the connector is weather proof, it can appear to be connected when in fact it isn't. I would pull the connector out, inspect for water or damage, then plug it back together making sure it is fully seated.
The sensor does not work in a 'gradual' way, it either works or it doesn't. My car was in the dealer for some air conditioning work, they had to pull the sensor for some reason and neglected to fully seat the sensor connector upon reassembly. We noticed it not working when we arrived home from the dealer. I called the dealer for assistance in finding the sensor, while awaiting call-back, I went on the internet, found out where the sensor was located, went out to the car, found the connector not fully seated, re-connected the sensor, turned the car on and it was functioning normally. No driving, no waiting, it either works or it doesn't.
