2011 Equinox stalling
This is a discussion on 2011 Equinox stalling within the 2010+ Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
2011 Equinox 2.4 AWD is stalling on start up. It happens using the electric start and the key. After it ...
Old 08-02-2017, 02:17 PM   #1 (permalink)
RRoark is on a distinguished road
Default 2011 Equinox stalling
2011 Equinox 2.4 AWD is stalling on start up. It happens using the electric start and the key. After it does it and I start it back up it runs perfectly. I have searched around and it doesn't seem like anyone else is having this issue.
Previously it had the stalling while driving issue. I put a new throttle body on and that fixed the issue. Two weeks ago I changed the 02 sensor in the manifold and relearned the throttle body thinking that was the issue. This took the problem away but this morning it came back again.
The car has 112K miles and has had the fuel pump replaced (recall), I replaced the exhaust manifold, Cam and exhaust sensors have been replaced. Plugs/wires done @ 80K, entire exhaust system replaced @ 70K (under federal emissions warranty). The car is maintained very well and doesn't get driven hard at all.
It doesn't throw any codes or anything so I am at a complete loss as to what is causing it.
RRoark is offline   Reply With Quote
Old 09-21-2017, 07:10 PM   #2 (permalink)
grendel20 is on a distinguished road
Most likely oil consumption. I'd have an oil consumption test done under the extended warranty
https://www.classaction.org/media/eq...l-bulletin.pdf
grendel20 is offline   Reply With Quote
2011 Equinox Stalling rarr201341 2010+ Equinox General Forum 3 09-29-2017 04:17 PM
06 Equinox Stalling | P0171 ResonantEcho 05-09 Equinox General Forum 0 06-20-2017 12:26 AM
2011 Equinox Stalling btweymouth1s 2010+ Equinox Maintenance 0 04-19-2016 09:45 AM
2011 equinox stalling issues? Low4x4 2010+ Equinox General Forum 138 04-16-2016 02:04 AM
CEL Stalling and no oil xx1jpt5xx 2010+ Equinox General Forum 1 12-09-2013 11:59 PM
