2011 Equinox Catalytic Converter
This is a discussion on 2011 Equinox Catalytic Converter within the 2010+ Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
Around 53,000 miles I had to have the Catalytic Converter changed out. Nw at 127,000 miles it needs to be ...
Old 10-06-2015, 11:57 AM   #1 (permalink)
Greg1456 is on a distinguished road
Default 2011 Equinox Catalytic Converter
Around 53,000 miles I had to have the Catalytic Converter changed out. Nw at 127,000 miles it needs to be replaced again. Has anyone else had this issue? The dealer is saying it is because of the mileage.
Greg1456 is offline   Reply With Quote
Old 10-06-2015, 10:21 PM   #2 (permalink)
Ours has 105k on the factory Catalytic Converter.
Have you had the vehicle tuned up? I would be interested to know if you have had the plugs changed at any point. I mean, I normally change those Ac Delco plugs and if your vehicle was services with a junky spark plug or not at all. I fouled plug can cause some upstream problems that the computer is trying to fix by adding more fuel and air. This would make your vehicle run extremely lean with a lot more carbon emissions(causing the converter to go bad faster). It may not be enough to throw a engine light but any mechanic with the right computer would be able to see a pending or intermittent codes.
Just a guess but it's what I am leaning towards. Keep us updated, obviously at this point you can't really escape replacing the bad part but don't let them throw anything other than an OEM converter to ensure this time it lasts.
I hope this is helpful!
Old 10-06-2015, 10:22 PM   #3 (permalink)
Welcome to the site, BTW!
Old 11-03-2015, 01:22 PM   #4 (permalink)
First you have to determine if it's actually the converter that is the problem. How was this diagnosed? Was it a P code? What code?
Catalytic converters were designed to last the lifetime of the vehicle. If they are requiring replacement it's likely an engine related issue which is causing the failure of the cat. For example I owned an Infiniti M35 with the VQ35DE engine. They are infamous for leading valvecovers which leads to oil entering the combustion chamber and making it's way down to the cat. Oil and Cats to not like each other and Oil wins that battle.
I heard the 2.4L ecotec engines required rebuilding by GM due to excessive Oil use. This could be the catalyst for your converters death.
Old 01-04-2016, 10:33 PM   #5 (permalink)
What was the outcome of this?
Old 02-28-2016, 10:06 PM   #6 (permalink)
G089372 is on a distinguished road
Have an '11 Nox with the 4 cylinder engine. Engine oil problem caused timing chain to stretch, damaging cam and cylinders. Dealer replaced 100% under warranty. Afterwards, I got an intermittant Catalytic converter error. Logical. The engine ran hot from damage, burning off the inside of the converter. You may have had the same problem. Will have to replace my converter eventually.
G089372 is offline   Reply With Quote
2010 Equinox LTZ V6 - Catalytic Converter (Back of Engine) Replacement Procedure webdawg 2010+ Equinox Maintenance 5 03-19-2016 01:17 PM
Everything you will want to know about the 2011 Equinox dietz4ibanez 2010+ Equinox General Forum 1 08-09-2013 10:38 AM
ACC to MP3 Converter Z_Ghost The Lounge 10 12-10-2010 06:45 AM
2011 Equinox LTZ sulzbachk 2010+ Equinox General Forum 11 12-06-2010 07:28 PM
New look for 2011 Equinox. Shaggy 2010+ Equinox General Forum 1 06-27-2010 05:06 PM
