2010 2.4L Coolant Temp Sensor Location
This is a discussion on 2010 2.4L Coolant Temp Sensor Location within the 2010+ Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
Trying to find location of coolant temp sensor (ECT) on my daughter in law's 2010 2.4L Equinox. When you first ...
Old 08-31-2014, 01:52 PM   #1 (permalink)
bigmitch is on a distinguished road
Default 2010 2.4L Coolant Temp Sensor Location
Trying to find location of coolant temp sensor (ECT) on my daughter in law's 2010 2.4L Equinox. When you first start the car it is getting the AC off engine temp to high on the display. Which I know is bogus as the car just started up. It is throwing pending code P0128 which leads to the coolant temp being to low. Fan constantly running when driving and for about 5-10 minutes after you stop. Coolant temp indicator never moves. From what I've read it usually points to the thermostat being stuck open. I'd also like to check out the sensor but for the life of me I can't seem to find it. Any help and info you could provide would be greatly appreciated.
Scott
bigmitch is offline   Reply With Quote
Old 06-16-2016, 12:43 AM   #2 (permalink)
Jel0416 is on a distinguished road
Default Equinox Temp Sensor
For the 2010 4 cylinder 2.4:
it's located in the back of the engine, in between where the two hoses are that come from the heater core (on the driver side.) It took me a while to find it, too. And I couldn't reach it from the top, standing over the engine.... Had to jack the Nox up and take the driver side tire off, and even then, reaching it was a little cramped. -Have to move the cover off the sensor wire (there's like an insulator piece of some sort, just push it out of the way) then unplug the sensor (I could do it with my finger but a screw driver may be easier.) Next you'll need a 19 inch deep socket and a little faith. If you have the tools to give you a little room, it's doable. An extension or 2 and a universal joint probably would've made my life easier, but I was able to do it with just a ratchet and the 19.... Again, it's in a tricky spot, but totally doable. I realize I'm a couple years late posting to this, but maybe it can help someone else out. Just changed mine yesterday. No more "engine off due to high temp" message. I also had to clear the code (because unplugging the battery didn't work) but boyfriend got me an OBD Bluetooth scanner, so I could clear the "P-0128" or whatever code from my phone. All good now.
Now.... If only I could fix my oil consumption problem.....
Jel0416 is offline   Reply With Quote
Temp guage hot when cars not! Roslyn 05-09 Equinox Maintenance 2 08-07-2014 01:19 PM
O2 Sensor Replacement DVB1 05-09 Equinox Maintenance 0 02-12-2014 12:01 PM
PCV Valve Location DVB1 05-09 Equinox General Forum 2 01-11-2014 10:10 AM
Battery Location slabadie 2010+ Equinox Maintenance 7 10-08-2013 04:42 AM
MAF Location slabadie 2010+ Equinox General Forum 1 12-11-2011 12:35 AM
