Go Back   Chevy Equinox Forum | GMC Terrain Forum | Cadillac SRX Forum > GMC Terrain and Cadillac SRX General Discussion > GMC Terrain General Forum
Window Washer Fluid Leak
This is a discussion on Window Washer Fluid Leak within the GMC Terrain General Forum forums, part of the GMC Terrain and Cadillac SRX General Discussion category!
I just bought a 2014 GMC Terrain. I got a really good deal on it, but while test driving it ...
  • 1 Post By randylutz
Old 08-21-2014, 11:08 PM   #1 (permalink)
VAST is on a distinguished road
Default Window Washer Fluid Leak
I just bought a 2014 GMC Terrain. I got a really good deal on it, but while test driving it I did not check to see if the window washer fluid worked. It failed the safety inspection because of this.
I went and bought some washer fluid and put it in the reservoir...no leak. But when I try and run my fluid to my front windshield the washer fluid leaks all over by the drivers side front tire. I know the pump works, but I think that the hose might be broke or disconnected.
Does anyone know what to do? How do I go about fixing this problem? Any advice would be great.
VAST is offline   Reply With Quote
Old 08-22-2014, 10:28 AM   #2 (permalink)
Well i think the first thing i would do is get under the hood and try to find where the leak is coming from. If the hose is broken i would try to find some rubber hose i could bridge the break from and some small clamps to hold it together.
If you purchased from a dealer as a certified pre-owned i would take it back and have them fix it.
Old 03-31-2015, 04:43 PM   #3 (permalink)
thebluegoat is on a distinguished road
If you open your hood and pop off the trim piece that covers the length of the fender there is a washer hose connection there, sounds like it's either broken or wasn't connected properly.
thebluegoat is offline   Reply With Quote
Old 04-07-2015, 03:30 AM   #4 (permalink)
randylutz is on a distinguished road
Seems like you have a hose issue. If you just purchased it, your dealer should do something abt it. I'd call them and take it back.
mswerb likes this.
randylutz is offline   Reply With Quote
2014, gmc, terrain, windshield washer fluid
Window washer fluid / Wet frt. carpet krumb 05-09 Equinox General Forum 11 12-15-2018 01:17 PM
transmission fluid change '08 equinox crazyfists82 05-09 Equinox Maintenance 5 09-23-2014 09:27 AM
Help oil leak! SalsaNox 05-09 Equinox General Forum 3 06-24-2013 05:43 AM
Drain windshield washer fluid Ken Rosey The Official "How To:" Section 4 11-13-2011 03:03 PM
Ac Condensor Leak. SPH01 2010+ Equinox General Forum 12 02-09-2011 12:34 PM
