Towing
This is a discussion on Towing within the 2010+ Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
How realistic is the weight limits on the 2016 equinox, anyone have any experience towing heavier trailers.?...
Old 08-12-2020, 07:59 PM   #1 (permalink)
Sschlobohm is on a distinguished road
Default Towing
Sschlobohm is offline   Reply With Quote
Old 09-10-2020, 10:29 AM   #2 (permalink)
burnbomber is on a distinguished road
This is for my 2010 2.4. i do not know if your engine is the same. My book says it's OK for 1000 lbs without trailer brakes, and 1500 with trailer brakes. With the V6, can go to 3500 lbs.
I've towed a bunch, and can tell you that 1200 lbs is about the limit for the car. Get much over 1300, etc., the ride will hurt you. Enough that you'll want to stop and off load, to get to 1200-1300.
You know how an empty trailer feels--like it's not there. No problem going, stopping. Well, when loaded too much it will bounce the car, so it is reacting and getting pushed up and down by the trailer tongue. I don't like that, but that's me.
I've overloaded my trailer, lots. A standard Harbor Freight fold-up, 4 by 8 with box on it (half-ton load limit) I've revised the spring mounts, to get a couple inches more spring travel. And, I've put high pressure trailer tires (load C, not the crappy B's). Otherwise, the tires control the load. If you push them, be sure they're not aged, cause they will blow. The original B's lasted 16 years, and died on the road.
So, I use the pull rig, lots. Got divorced and moved everything in it, from S. Oklahoma to NW Missouri. I've pulled enough thru landfill scales to know tonnage I'm carrying. 1300 is my personal limit--I've pulled over a ton but local only. Extra heavy--here's my practice--no highway and get it off quick. Long road hauls, reduce load from 1800 more or less, to 1300. Lose that extra 4 to 500 lbs.
And, I'm curious too as to other long haul travel practices.
2017 Honda Pilot Elite AWD, new, top of the line loaded, splendid...the Pilot
2010 Chevy Equinox, 2.4 FWD, white with Brownstone leather...the Nox
1997 Mazda Miata, base NA with 15" OEM wheels and Oris windstop...the little red scooter
burnbomber is offline   Reply With Quote
Towing question jdiaz2177 2010+ Equinox General Forum 0 05-31-2020 12:23 PM
towing section? dietz4ibanez Site Comments, Suggestions and Questions 3 02-02-2020 09:17 PM
Anyone towing a travel trailer? Equi2 Towing 0 03-11-2017 12:42 AM
Towing a Cruze with a Equinox Bigun08 Towing 9 10-08-2012 04:22 PM
2010 Towing gappvembe The Official "How To:" Section 3 04-09-2012 11:26 PM
