Stabilitrack/ ABS light on after doing new Brakes and rotors
This is a discussion on Stabilitrack/ ABS light on after doing new Brakes and rotors within the 2010+ Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
I have a 2011 Equinox LT I replaced the pads and Rotors, now the Stabilitrack and ABS light have came ...
Old 11-26-2015, 01:10 PM   #1 (permalink)
scotty2666 is on a distinguished road
Default Stabilitrack/ ABS light on after doing new Brakes and rotors
I have a 2011 Equinox LT I replaced the pads and Rotors, now the Stabilitrack and ABS light have came on. Anyone have any idea why??? I didn't touch anything to cause this issue. Just replaced the Pads and rotors... UGH
scotty2666 is offline   Reply With Quote
Old 11-26-2015, 03:17 PM   #2 (permalink)
Get the codes pulled.
Old 11-30-2015, 03:20 PM   #3 (permalink)
got the codes replaced both Front and rear ABS sensors, issue has not gone away.
Old 11-30-2015, 07:53 PM   #4 (permalink)
Have you reset the ECU after replacing the ABS sensors? I can't recall what the issue was before but I had that happen to me and I did something to fix it but can't remember what. It was back in 99. Maybe leaving the battery unplugged overnight?
Old 12-01-2015, 07:40 AM   #5 (permalink)
I got the vehicle rescanned and the codes cleared with the scan tool at oreilleys but it came back on a mile down the road. only thing I haven't replaced are the hub bearings, and well they aren't cheap. the rear is $90 for the 1 yr warranty and the front is $120 for the 1 yr warranty.
Old 12-02-2015, 05:23 AM   #6 (permalink)
Bearings or hub assemblies wouldn't be an issue unless you are hearing a groaning sort of sound which gets louder as you drive faster.
Did some reading and most people were successful by either replacing the speed sensors in the hub or checking the hub rings. One guy took the hub assembly apart and found his ring was missing teeth! How the heck would that happen unless the hub bearing was so badly worn it was wobbling. Anyway check the wiring harnesses while you're at it.
Old 12-02-2015, 06:56 PM   #7 (permalink)
I replaced both front and rear ABS sensors. the rear one was VERY difficult to replace in fact the end broke off while I was extracting it from the hub, hence I had to remove the hub entirely to get the broken piece ABS sensor out of the hub. I did in fact look inside at the teeth and saw no abnormalities, so I reinstalled it back on the vehicle with the new sensor. The front sensor was easily replaced looking inside the hole for the front hub was not easily done but what I could see didn't throw and red flag up. I was told there is a magnetic ring inside there and it could be cracked causing the issue.
Old 12-19-2015, 09:54 AM   #8 (permalink)
solution solved replaced passenger side wheel bearing, problem went away! apparently there is a thin magnetic strip around the back of the bearing that looked to be missing small pieces from it. you cant see this strip unless the bearing is removed from the steering knuckle.
Old 12-19-2015, 08:47 PM   #9 (permalink)
had the same trouble on my 07, too bad GM aren't able to make good bearings/sensors combo. Sometimes the bearing make noise, when the bearing is ok the sensor is bad... oh my haha
Old 01-04-2016, 10:40 PM   #10 (permalink)
I think that there is a TSB about this, if you clean that area on the back of the hub, this should fix the problem.
If not, replace the hub.
Old 01-04-2016, 11:10 PM   #11 (permalink)
You can also check in the plugs of the sensor, one of my wheel sensor was coding and there was corrosion inside the connector, cleaned it and the code went away
Brake Rotors Turned. dietz4ibanez Suspension and Brakes 8 10-06-2014 09:29 PM
Les talk Brakes TheDarkKnightKnox 2010+ Equinox Maintenance 0 04-18-2014 12:55 PM
MIL Light, Traction control light, Brake light, ABS light rlrnr53 05-09 Equinox General Forum 3 12-27-2013 06:38 AM
Baffled By Brakes Falken79 2010+ Equinox General Forum 7 07-09-2012 01:25 PM
student research on new rotors. need your opinions litebrake 2010+ Equinox General Forum 5 07-01-2012 01:39 PM
