06-15-2015, 08:24 PM
#2 (permalink)
the system is protected against running without or with too much refrigerant. In both ways it will not turn on. If you can find a cheap garage that have a Nitrogen tank, plug it on your high pressure system (red tip, bigger one) when you turn on the nitrogen valve, you will ear if there is a leak on the system.
