exterior lamp behavior
This is a discussion on exterior lamp behavior within the 2010+ Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
hi, for chevy equinox 2010 2.4 ltr: 1- i can not turn off the exterior lamps while the transmission lever ...
  • 1 Post By Starfire
Old 03-01-2018, 08:32 PM   #1 (permalink)
mnewiraq is on a distinguished road
Default exterior lamp behavior
hi,
1- i can not turn off the exterior lamps while the transmission lever is on D, even if the setting ring is on off mode. any idea please?
2- back lift key is not working in fob? any solution?
rgds,
mohammed
mnewiraq is offline   Reply With Quote
Old 03-02-2018, 11:17 PM   #2 (permalink)
Starfire is on a distinguished road
I'm sure you have your reasons, but why would you want to turn off your lights if you are in drive? But, are all your outside lights on (headlights and tail lights) or just the headlights? If it's just the headlights, those are your DRL's or Daytime Running Lights. I'm not sure they can be turned off.
Regarding the fob, does the power liftgate not operate with either fob, or only with one?
mnewiraq likes this.
2010 Chevrolet Equinox LT FWD Black Granite Metallic
2010 GMC Terrain SLT AWD Quicksilver Metallic
2012 Chevrolet Cruze Eco Ice Blue Metallic
2017 Chevrolet Equinox LT AWD Summit White
Starfire is offline   Reply With Quote
Old 03-03-2018, 01:25 AM   #3 (permalink)
Those are the head lihts that been controlled by rotating the ring on the light lever. In iraq we had to turn off the lights in the night as we approach the military check points as per the instructions because the lights affect the security forces members.
Regarding The lift gate, it is working normal through its built-in button but i can not open it using the fob for unknown reason!.
05-09 Equinox Exterior help adaml23 Exterior Modifications 0 07-31-2015 09:10 AM
