android auto 2018 equinox
This is a discussion on android auto 2018 equinox within the 2010+ Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
on my new 2018 equinox the android auto system was working fine till about 2 days ago now it is ...
Old 09-25-2017, 11:04 AM   #1 (permalink)
zinzoid is on a distinguished road
Default android auto 2018 equinox
on my new 2018 equinox the android auto system was working fine till about 2 days ago now it is freezing up all the time I have tried changing cable and a different phone but same thing.
anyone else having this trouble?
zinzoid is offline   Reply With Quote
Old 09-26-2017, 06:45 AM   #2 (permalink)
jsfb6pts's Avatar
Mine has not had any issues .( knock on wood )
Old 09-26-2017, 08:25 PM   #3 (permalink)
18nox's Avatar
18nox is on a distinguished road
No issues with mine.... yours would be the first I've heard of.
I checked and there does appear to be some update/reset options in Settings.
Did you try these:
*Settings/Software Information/Software Update
OR
*Settings/Return To Factory Settings/Restore Radio Settings
If that doesn't work, you can try disconnecting the battery** (negative terminal), then hold your foot on the brake petal to completely drain the capacitors of all the reserve power, to be sure the power is completely removed from the electrical system/radio. Then, reconnect to see if that clears it up.
**However, be sure to research whether or not your head unit has a security code that might need to be entered at first boot up. Do your homework and locate that first before completely disconnecting the power.
If that doesn't work, call the dealer and make an appointment. That warranty is there for a reason.
Good luck and keep us posted!
18nox
2018 Pepperdust Metallic 2LT AWD
-LTG Intercooled 2.0T DOHC SIDI, VVT
-GM Hydra-Matic 9T50 9-Speed Auto
18nox is offline   Reply With Quote
Old 09-27-2017, 04:06 AM   #4 (permalink)
I found the trouble it was the cable some cable work some don't does not matter if it is OEM or not.
thanks for the help
2018 Equinox auto stop/start not kicking in jberry3721 2010+ Equinox General Forum 29 09-27-2019 10:29 PM
2018 Equinox jsfb6pts 2010+ Equinox General Forum 18 05-18-2018 08:15 PM
Android/Equinox audio integration. dietz4ibanez Audio & Electronics 11 05-01-2012 05:49 PM
Tapatalk widget on android phones. Iphone? dietz4ibanez Site News 16 09-27-2011 10:31 PM
Google's Android leads U.S. smartphones dietz4ibanez Consumer Eletronics 16 11-21-2010 02:04 AM
