2019 ice failures! Help!
Hello,
A brand new Equinox owner here and my first post!
Got a question I can't find any info on, anywhere, hopefully someone on this site can give me some advice.
Just picked up a 2019 Eq 2.0T Premier with just about every option. After just a couple days of ownership and only 41 miles on the odometer, we had to head out on a trip to lower Michigan for a family emergency, from the frozen U.P.. On the way south, we hit a nasty snow/ ice storm (common up here). As the snow turned to ice, and began to build up on the vehicle and the various cameras and sensors, a lot of my driving aids started shutting down. This included the lane keep assist, the intellibeam headlights, and the adaptive cruise. This is not a surprise and totally makes sense, in fact I even got several messages saying ice was on the windshield blocking the camera behind the mirror.
What was a surprise though, is after a little while, my navigation screen turned off, and said "SD card removed", which was not true, as the SD card reader (which is in the front center cubby of the dash) was never touched. Efery time you tried to activate the nav, you got the SD card has been removed error. When I tried to reseat the SD card, I noticed the normally lit white surrounds around the various devices of the SD card reader (USB port, and other outlets) were out. Also, all of the USB ports failed (both front and inside the console). Seems like this SD device and USB ports may have lost all power. Hence my nav failed, along with all USB charging and Android Auto connectivity.
So, as we got to slightly warmer weather, and the ice was slowly melting, I pulled over and cleaned the windshield ice blocking the camera (it was covered pretty badly). I also shut down and restarted the vehicle several times. As I expected, the LKAS function returned, along with intellibeam high beams. However, the SD card reader stayed blacked out and the adaptive cruise still failed along with the nav, Android Auto and other USB ports. Manual cruise worked. Not happy, I assumed I blew a fuse that handled this SD and USB port functions. While the owner's manual was not specific, I narrowed it down to fuses F36 or F39 in the dash fuse panel....
When we finally arrived, after unloading all the stuff, I went out to the garage, to check the suspected fuses.....but to my surprise, the SD card reader was now lit up, and all functions (nav, USB and adaptive cruise) were working perfectly!
So, this is where I need some good advice! While I can see the ice causing the LKAS and intellibeam failures, I can't see why it would shut down the all power to the SD card reader and it's related functions. And why did it come back afterwards, before I even checked the fuses? Only logical explanation I can come up with is that possibly a loose or flaky fuse, but with today's cars, you never know how they are wired and interconnect.
I do plan on reseating the fuses and hope that helps, unless the problem returns, than I am heading to the dealer asap.
Any advice or thoughts would be appreciated.
Thanks, Randy
