2018 Questions
This is a discussion on 2018 Questions within the 2010+ Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
I got a 2018 LT, Confidence and Convenience a few days ago. Everything is great, except: The radio is way ...
Like Tree4Likes
Old 05-28-2017, 10:20 PM   #1 (permalink)
ArgusMcJohnsten is on a distinguished road
Default 2018 Questions
The radio is way too bright at night. It doesn't dim at all when the headlights come on, and the dimmer knob has no effect on it at all. I can't find anything in the settings either. The manual, probably just a generic picture, shows lighting and climate buttons on the home screen, but I don't have either of those.
Not an issue, just a question, is the cruise control supposed to be always on? As soon as I start up the car, the light is on, but grayed out.
Minor gripe, more about android than the car. I wish I could keep bluetooth streaming going through an unsupported app and have maps going on the display through Android Auto.
I think that's all for now.
Aheckm likes this.
ArgusMcJohnsten is offline   Reply With Quote
Old 05-30-2017, 06:36 AM   #2 (permalink)
jsfb6pts's Avatar
I have the 8" radio I'll check the dimmer later .
My cruise on/off button is on the left side of the steering wheel .
I dont care for the andriod auto ,because you Have to use a cable . I have tried it ,but dont use it
Old 05-30-2017, 10:09 AM   #3 (permalink)
gpart is on a distinguished road
The dimmer knob to the left of the steering wheel on the lower dash has very little effect on the overall radio display, from what I've perceived by playing around with everything.
From memory, you'll need to select "Settings" on the touch screen Home Page, then select the sub-menu for either "Display" or "Vehicle". That contains a setting which will alter the display lighting. When you find the "Display" menu, select "Auto" so that the MyLink system will automatically adjust the lighting to what is best given the conditions it perceives.
Please keep us posted on whether you're able to solve this issue or need further assistance.
2018 Equinox
1.5L AWD Premier
"Sun, Sound & Nav. Pkg."
gpart is offline   Reply With Quote
Old 05-30-2017, 01:39 PM   #4 (permalink)
I'll look around again in the menus, but I couldn't find anything that said display. I may stop back in the dealer since I have to drive by there later anyway.
Old 05-30-2017, 05:28 PM   #5 (permalink)
Found out everything is as it should. The sensor is more sensitive than I thought it would be, and I didn't realize that controlled the dash brightness even if the headlights are turned on. Once we played with that, even at the dimmest it seems bright to me.
The other ones at the lot don't have an option in the display menu either.
Tatumd78 likes this.
Old 05-31-2017, 07:59 AM   #6 (permalink)
Glad you were at least able to get to the bottom of it, even if it isn't to your utmost satisfaction (yet).
2018 Equinox
1.5L AWD Premier
Old 05-31-2017, 09:07 AM   #7 (permalink)
jsfb6pts's Avatar
My dimmer will black out the radio ( and the dash ) .When the lights are on .If the lights are off ,it has no effect on anything
Old 06-01-2017, 10:17 AM   #8 (permalink)
I'll need to try that out. Haven't thought of that since I don't drive at night very often.
2018 Equinox
1.5L AWD Premier
Old 06-04-2017, 06:42 AM   #9 (permalink)
jsfb6pts's Avatar
I dont either ,cant see as well at night as I used to
Old 09-10-2017, 08:35 AM   #10 (permalink)
duke94 is on a distinguished road
Has anyone figured out how to dim the display? I can't believe GM Engineers let this go into production. My 2015 would dim with the dash lights.
duke94 is offline   Reply With Quote
Old 09-11-2017, 10:19 AM   #11 (permalink)
The instrument panel dimmer switch is located on the lower left dash next to the steering wheel and should be the left outermost knob next to the headlight knob which is the center one and the right most knob for the fog lights (p. 157).
The 7" or 8" display can be set to either "day", "night" or "auto" display or can be re-calibrated via the "vehicle settings" menu (p.150). I believe the engine may need to be running to access / change some of the vehicle settings.
My IP / Nav display seems to work fine. Sometimes the Nav display will adjust the lighting as I'm driving due to outside lighting conditions.
If neither of those work, a dealer service visit may be in order.
2018 Equinox
1.5L AWD Premier
Old 09-12-2017, 05:38 AM   #12 (permalink)
jsfb6pts's Avatar
Anyone else notice that the passenger seat is narrower than the drivers seat ?
gpart likes this.
Old 10-03-2017, 09:41 PM   #13 (permalink)
Aheckm is on a distinguished road
Default 2018 Equinox Display Brightness
I just purchased a 2018 Equinox and have tried the suggestions in this forum without much luck! Any new findings? I do not have a display option in settings either and cannot believe there is no way to turn the brightness down.
Aheckm is offline   Reply With Quote
Old 10-03-2017, 09:42 PM   #14 (permalink)
kastner03 is on a distinguished road
my dimmer next to the headlight switch dims my radio display maybe something is wrong with yours ?
kastner03 is offline   Reply With Quote
Old 10-03-2017, 10:07 PM   #15 (permalink)
I did try that and it only adjusted the speedometer display and not the 7 inch radio display area.
2018 Equinox jsfb6pts 2010+ Equinox General Forum 18 05-18-2018 08:15 PM
2018 Equinox Issues jsfb6pts 2010+ Equinox General Forum 23 05-23-2017 05:15 AM
Just bought New 2018 Premier tbeasl38 2010+ Equinox General Forum 5 04-24-2017 04:48 AM
2018 equinox spotted kastner03 2010+ Equinox General Forum 0 02-28-2017 09:39 PM
[Long Post. 6 Questions]Brand new Equinox owner Many questions OklahomaHoss 2010+ Equinox General Forum 2 08-07-2016 12:53 AM
