2018 Equinox Heater Blower Issue
This is a discussion on 2018 Equinox Heater Blower Issue within the 2010+ Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
Like Tree3Likes
Old 11-05-2017, 12:59 AM   #1 (permalink)
TessaNorth's Avatar
TessaNorth is on a distinguished road
Default 2018 Equinox Heater Blower Issue
Iíve noticed that when I remote start my vehicle, my fan does not kick in. My climate control is manual (dials) Hereís what Iíve tried so far to see if it kicks in, none of these methods worked:
-starting with both the remote and app.
-starting with the Dan speed at medium and low
-running remote start for 20 mins instead of 10
-remote start at -4c
-remote start at -20c
-remote start after driving for 20 mins
The owners manual says it should run at the settings it was set at when it gets turned off. There is nothing in my touch screen vehicle comfort or climate control settings and nothing in my dash controls.
Dealership is at a loss, no clue whatís happening.
Given its winter and I live in Northern Alberta, would be nice to have the fan defrost my windshield!
TessaNorth is offline   Reply With Quote
Old 11-11-2017, 06:13 AM   #2 (permalink)
jsfb6pts's Avatar
Mine does the same thing ,just finding out because it just got cold here .Air worked fine last summer .I have been experimenting the past few days,turned up the fan and the temps ( dual zone ) max and it did work
Other thing I noticed is a high pitch whine from the blower/fan motor @ low speed ,radio needs to be low or off to hear it .
Old 11-11-2017, 10:36 PM   #3 (permalink)
Pauline is on a distinguished road
I have the same issue. Going to see dealer who sold me the car. Isn't this the whole reason for remote start to get into a warm car! Very disappointed
gpart likes this.
Pauline is offline   Reply With Quote
Old 11-12-2017, 06:26 AM   #4 (permalink)
jsfb6pts's Avatar
Mine works when I turn the fan on high and the temp all the way up .
Do you also have that high pitch whine ?
Old 11-15-2017, 10:09 AM   #5 (permalink)
Pcrecord is on a distinguished road
I also have the ISSUE and will try to put everything to max. But I'm sure it's a software issue...
If they can do auto defrost, it shouldn't be a problem...
Pcrecord is offline   Reply With Quote
Old 11-15-2017, 09:14 PM   #6 (permalink)
Tried putting fan on high the night before..nothing. have my dealership looking into it. Hopefully they will find an answer.
Old 11-17-2017, 10:59 AM   #7 (permalink)
gpart is on a distinguished road
I checked mine via remote start on two occasions over 2 separate days. There don't appear to be any issues with the blower and settings in mine, as far as I can tell.
"Auto" settings turn on fan (I've got mine set to low) and turns on the rear auto defrost (I set this in the "Settings" under "Vehicle"), even if the rear window doesn't have frost on it (I'm guessing it's all related to the temperature the system perceives).
I don't know if it matters but mine is an early build and purchased it in mid-April.
2018 Equinox
1.5L AWD Premier
"Sun, Sound & Nav. Pkg."
gpart is offline   Reply With Quote
Old 11-18-2017, 06:56 AM   #8 (permalink)
jsfb6pts's Avatar
My rear defrost come on with the remote start also .
Mine was built the 2nd day of production . 1/10/17 Ordered in November of 16 ,was not able to take delivery until March because of quarantine
Old 11-18-2017, 08:23 AM   #9 (permalink)
The last two replies...do u two have a 2018 equinox LT? Yes funny how rear defogger works! Still waiting to hear from my dealer.
Old 11-20-2017, 10:27 AM   #10 (permalink)
I also have the issue, the heated seat and rear defrost works but not the fan/heat
This happens below 7c and it works when temperature is higher. I tried putting everything to full and all other suggestions.
I called my dealer which said they received a note to not work on this trouble because GM is working on an update for the computer.
This is very unfortunate but I guess we will have to wait.
I have an appointment for my tires in 2 weeks and hope they will get it before then.
TessaNorth likes this.
Old 11-21-2017, 09:37 PM   #11 (permalink)
TessaNorth's Avatar
Yes it’s very disappointing. The first time I ever have had command start and I still need to go outside and start my car. Chev corporate customer service replied to a Facebook message I sent regarding th issue and they’re looking into it and contacting the dealer.
Old 11-21-2017, 09:39 PM   #12 (permalink)
TessaNorth's Avatar
Yes. 2018 LT
Old 11-21-2017, 09:39 PM   #13 (permalink)
TessaNorth's Avatar
No high pitched whine at all.
Old 11-27-2017, 06:17 AM   #14 (permalink)
jsfb6pts's Avatar
Yes, I have an LT
Old 12-06-2017, 04:40 PM   #15 (permalink)
Ok just for those like me who are still waiting ;
Last weekend, I went to the dealer and they did 3 system updates available form GM and it didn't fix the problem. The dealer will contact head office and report the problems still exist.
Again, fans remote start work when outside temperature is higher then 7 degrees but won't when temp is lower...
2018 hvac, heater motor, remote start heat
2018 Display Brightness issue Aheckm 2010+ Equinox General Forum 18 08-07-2019 07:04 AM
2009 Equinox seat heater med1881 2010+ Equinox Maintenance 0 01-27-2017 02:13 PM
Burnt blower motor control switch ! Help! Youtube_mechanic 05-09 Equinox Maintenance 0 03-15-2016 07:34 PM
Blower problems Jaws 05-09 Equinox Maintenance 9 12-12-2015 04:09 PM
