2018 Equinox Diesel - Cooling fan not running when A/C is in use.
This is a discussion on 2018 Equinox Diesel - Cooling fan not running when A/C is in use. within the 2010+ Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
We started having problems with the A/C not blowing cold unless the car was moving. I originally thought that it ...
Old 07-08-2019, 09:06 PM   #1 (permalink)
TonyLudwick is on a distinguished road
Question 2018 Equinox Diesel - Cooling fan not running when A/C is in use.
We started having problems with the A/C not blowing cold unless the car was moving. I originally thought that it was low on refrigerant and that it was cooling when the car was moving because the compressor was running faster due to the higher engine rpms when the vehicle is in motion. It turns out that the root of the problem is the cooling fan is not running when the A/C is on resulting in no air passing through the condenser unless the car is moving. We have not had any problem with the engine overheating, so I believe that the fan is functioning when the engine needs it to. So for some reason the cooling fan is not running when the A/C needs it to, which is whenever the A/C is on. Does anyone know if there is a separate fuse or relay circuit that the A/C uses to turn the fan on? What would be the quickest way to diagnose what is at fault considering the facts above? Any help would be appreciated.
Thanking you in advance.
Regards,
Tony
TonyLudwick is offline   Reply With Quote
a/c, ac not working, cooling fan, diesel, equinox
2018 Equinox Diesel - Cooling fan not running when A/C is in use. TonyLudwick 2010+ Equinox Maintenance 0 07-08-2019 01:26 PM
2018 Equinox 1.6 T Diesel fuel filter reset onerpm49 05-09 Equinox Maintenance 3 06-19-2019 02:26 PM
2018 Diesel Mileage red70judge 2010+ Equinox General Forum 22 05-19-2019 06:21 PM
2011 equinox running rough Ftrevino19 2010+ Equinox Maintenance 0 11-26-2018 07:48 PM
07 equinox cooling system completelystumped 05-09 Equinox Maintenance 4 11-18-2013 09:40 PM
