2018 2.0 9th gear vibration noise
This is a discussion on 2018 2.0 9th gear vibration noise within the 2010+ Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
I just purchaed a used 2018 Equinox Premier with 2.0 AWD with 22K miles on it. The motor seems to ...
Old 09-29-2020, 10:22 AM   #1 (permalink)
Albow77 is on a distinguished road
Default 2018 2.0 9th gear vibration noise
I just purchaed a used 2018 Equinox Premier with 2.0 AWD with 22K miles on it. The motor seems to run smooth and tranny seems good also. I did notice that when traveling at about 60mph and it shifts into 9th gear, there seems to be a vibration that comes from the drive terrain that causes a bad drone noise in the cab. The door panels will vibrate and it is just anoyoing. It will do it when the motor is getting lugged at about 1500 rpm. If you give it more/less gas with out it kicking out of 9th gear, you can vary the vibration and noise in the cab. Is anyone else experencing this issue?
Albow77 is offline   Reply With Quote
Shimmy/vibration nsmilligan 2010+ Equinox Maintenance 0 07-30-2018 03:37 PM
Cabin Vibration when A/C is on GhostyOwnage 05-09 Equinox General Forum 0 05-27-2018 07:22 PM
Vibration in 2018 equinox jonesier 2010+ Equinox General Forum 2 01-05-2018 12:21 PM
Rear vibration comes and goes Willcruz82 05-09 Equinox Maintenance 2 06-20-2017 03:48 PM
Rear end vibration prheaume 05-09 Equinox Maintenance 8 05-27-2016 08:00 PM
