2017 equinox bent metal under antenna base leak
This is a discussion on 2017 equinox bent metal under antenna base leak within the 2010+ Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
Hey, I backed up into the garage door when it didn't fully open. The antenna caught the bottom of the ...
Old 08-08-2020, 11:47 PM   #1 (permalink)
tbu
tbu is on a distinguished road
Default 2017 equinox bent metal under antenna base leak
Hey,
I backed up into the garage door when it didn't fully open. The antenna caught the bottom of the door and snapped off of the base. The metal on the roof around the hole for the antenna base bent upwards.
I've flattened the metal as best i can. I also installed a new antenna base, but there is a leak now.
I took the new base off again and applied some waterproof silicone sealer, but there is still some water coming through.
What are my options to fix this?
I found this: https://www.amazon.com/Gorilla-42425...+epoxy+&sr=8-3
Do you think a bead around the roof opening will solve the problem?
tbu is offline   Reply With Quote
2010 Equinox XM Radio Antenna Base Walt Audio & Electronics 0 12-26-2016 04:08 PM
05 equinox oil leak Knexster 05-09 Equinox Maintenance 1 01-06-2016 06:09 PM
Metal on the front? 12nox Towing 5 04-08-2015 02:55 AM
Lil Will CB antenna in back of OnStar antenna parlyle Audio & Electronics 5 10-15-2011 09:42 PM
2012 Adding USB port on base model Controllerkk 2010+ Equinox General Forum 1 08-24-2011 10:46 PM
