-   -   2011 Equinox Stalling (http://www.chevyequinoxforum.com/f4/2011-equinox-stalling-1885/)
rarr201341 07-13-2017 02:45 PM
I have a 2011 Equinox that is periodically stalling and hesitating. After the third time it stalls the check engine light comes on and either the code P0420(catalytic converter) pops or code N/a pops. I have recently replaced both O2 sensors and the catalytic converter. Issue has continued to occur. Has anyone had the same issues, and if so how were they resolved?
ls973800 07-21-2017 08:07 PM
Have the throttle body checked. I think there was some extended warranty for that problem on certain years.
If you have the 4 cylinder engine have you had excessive oil consumption along with the poor engine performance?
americanfoxusa 07-22-2017 06:48 PM
I had the same issue on my 2011 and I changed the sensor, stopped the oil consumption. But also had an oil consumption log at the dealership and after 10 visits and 3 months later they finally did the job for free.
Check the code I have and maybe that's the easy fix for you.https://uploads.tapatalk-cdn.com/201...7b778f253d.jpg
Sent from my SM-G930P using Tapatalk
grendel20 09-29-2017 04:17 PM
Oil consumption issue. go to the dealership, request an oil consumption test under TSB 16118 and see if they have to replace the pistons in the engine.
