13 equinox piston rings cause oil leaks?
This is a discussion on 13 equinox piston rings cause oil leaks? within the 2010+ Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
has this ever happen to other members? piston ring causes oil leak and engine seizure...
Old 09-09-2020, 01:24 PM   #1 (permalink)
djwolfe is on a distinguished road
Default 13 equinox piston rings cause oil leaks?
djwolfe is offline   Reply With Quote
Old 09-21-2020, 06:06 PM   #2 (permalink)
skitchin1 is on a distinguished road
There a pcv hole between intake manifold and block. That plugs up. And will pressurize the engine tell a gasket goes. Take off high pressure fuel pump and intake man and right in the center inline with the block hole and open it up with drill bit.
skitchin1 is offline   Reply With Quote
13 equinox piston ring issue? djwolfe 2010+ Equinox Maintenance 0 09-09-2020 01:20 PM
2011 Equinox LTZ Piston change blackmax100 The Official "How To:" Section 1 06-05-2019 06:20 PM
Sunroof leaks. Any suggestions? roscoe63 The Official "How To:" Section 3 11-28-2011 08:37 PM
Help!!! 2011 nox ltz leaks 99camaross 2010+ Equinox General Forum 3 10-24-2011 10:48 PM
