Go Back   Chevy Equinox Forum | GMC Terrain Forum | Cadillac SRX Forum > Equinox, Terrain & SRX Knowledge Center > Equinox, Terrain + SRX Recalls
Water in Spare tire well
This is a discussion on Water in Spare tire well within the Equinox, Terrain + SRX Recalls forums, part of the Equinox, Terrain & SRX Knowledge Center category!
I have a 2007 Equinox and am continuing to have issues with water getting in the spare tire well. Is ...
Old 08-08-2013, 04:42 PM   #1 (permalink)
skippy588 is on a distinguished road
Default Water in Spare tire well
I have a 2007 Equinox and am continuing to have issues with water getting in the spare tire well. Is this a common issue? How do you remedy?
skippy588 is offline   Reply With Quote
Old 08-21-2013, 12:37 AM   #2 (permalink)
Chasing water leaks like this is not fun! Probably the easiest way would be to drop the headliner on the back end of the vehicle and take it through the car wash. Or you can have someone spray water on the car while you are inside.
Another thing to check is for factory holes for draining water that should have a rubber grommet that may be allowing water in but not draining.
If I had to guess, something may not be right with the rubber gaskets around the back cargo area opening.
Old 11-23-2014, 05:40 PM   #3 (permalink)
toyhauler1283 is on a distinguished road
I had this same problem with my 2005 and it was the way gm put the sunroof together the seams needed more silicone. The water would run down the rlheadliner in behind the panels and soak the trunk and floor
toyhauler1283 is offline   Reply With Quote
Old 02-01-2015, 10:42 PM   #4 (permalink)
I have a oldsmobile that I just drilled a hole in the floor to let the water drain out. Maybe one of these days, I will have time to fix it!
Old 04-17-2015, 01:28 AM   #5 (permalink)
3fingers is on a distinguished road
I agree I recently had the same issue upon checking it out it was the sunroof seams that was leaking. Just apply additional silicon around the seam and your good to go.
3fingers is offline   Reply With Quote
Old 05-15-2015, 05:11 AM   #6 (permalink)
This seems to be a common problem with Chevy Equinox.
Old 05-20-2015, 09:50 AM   #7 (permalink)
A W Warn is on a distinguished road
There have been several Technical Service Bulletins (TSB's) issued for a variety of water leaks in the Equinox and Terrain.
If I remember correctly, there are two main issues in the Equinox:
1. Where the tail light wires penetrate the car body, the grommet leaks or a grommet does not exist. Use caulk (type spec'd by GM) to seal the leak.
2. In some cases, sealant is missing around the perimeter of the rear hatch door. Use caulk (type spec'd by GM) to seal the leak.
Alan
2015 Equinox LTZ
A W Warn is offline   Reply With Quote
Old 05-20-2015, 10:11 AM   #8 (permalink)
Default Water in spare wheel well
Found this online
http://www.justanswer.com/uploads/Bl...water_leak.pdf
Alan
2015 Equinox LTZ
Old 09-09-2015, 11:06 PM   #9 (permalink)
Yup heard a lot of complains about this with my fellow friends with their equinox. Manufacturer should call this as a recall.
Old 09-10-2015, 08:52 AM   #10 (permalink)
The water may come from the tail lights.
Old 02-14-2016, 10:45 PM   #11 (permalink)
That is one area to look out the tail light seals another is the mastic seal.
Chevrolet Equinox Questions - does anyone else have a water leak on 2006 equinox?? My entire spare t... - CarGurus
Old 02-18-2016, 09:47 PM   #12 (permalink)
What I did to check is to have someone inside the cabin with a flash light and me out side hosing down all the rear areas so that the person inside could inspect thoroughly where the leakage is coming from.
Old 08-06-2020, 03:53 PM   #13 (permalink)
JLD_HOUSTON, TX is on a distinguished road
Default Water Leak into the spare compartment
See attached pictures of a 2014 Terrain, holes factory made UNDER THE TAIL LIGHTS, one hole on each tail light of about 3 in x 3 in covered by tape similar to the duct tape, this tape starts curling over the time exposing the hole on the body of the car, when water runs thru the gap around the tailgate goes right in to the trunk or spare compartment, it's very obvious how dumb USA auto industry is, I can't believe that any foreign vehicle is way more quality than USA ones, it;s embarrassing. I had to take off the trim by the latch and both sides panels in order to track the incoming water after I opened the water hose aiming to were the tailgate gap is, nothing to do with gaskets or mastic or anything like that, it was just the poor quality of the most vehicle made in USA.
In order to fix it I used A/C metallic duct tape along with E6000 glue, NO MORE LEAKS SINCE..
JLD_HOUSTON, TX is offline   Reply With Quote
2007 equinox, water
Tire Pressure Monitors Ken Rosey 2010+ Equinox Maintenance 22 11-21-2017 06:08 AM
Tire shine Lenn Detailing Tips and Tricks 24 03-20-2014 09:50 PM
Tire/Wheel Changeover Ken Rosey 2010+ Equinox Maintenance 2 11-21-2012 08:04 PM
Tire inflation sticker mswerb 05-09 Equinox General Forum 2 10-04-2012 11:27 AM
Winter tire anytime? prheaume Exterior Modifications 9 02-02-2012 11:30 AM
