Go Back   Chevy Equinox Forum | GMC Terrain Forum | Cadillac SRX Forum > Equinox, Terrain & SRX Knowledge Center > Equinox, Terrain + SRX Recalls
Moisture in Headlights
This is a discussion on Moisture in Headlights within the Equinox, Terrain + SRX Recalls forums, part of the Equinox, Terrain & SRX Knowledge Center category!
As if it is a recall I have not a clue. But what I can tell you is that the ...
Old 05-23-2012, 01:13 PM   #1 (permalink)
1sLoY7's Avatar
1sLoY7 is on a distinguished road
Default Moisture in Headlights
As if it is a recall I have not a clue. But what I can tell you is that the dealer has changed my headlights for moisture in them. I have read it was a recurring problem so it may help some of you out with water in your headlights if you are still within warranty or know someone at a dealer.
Built not bought!
1sLoY7 is offline   Reply With Quote
Old 05-23-2012, 08:57 PM   #2 (permalink)
Did you have a photo with the moisture in the headlight?
Old 05-23-2012, 09:03 PM   #3 (permalink)
1sLoY7's Avatar
No I didn't get one but I will probably get one the next time we get a hard rain and get to drive in it. I actually get to go back to the dealer when I get on land. I noticed it again right before I came back to work.
Built not bought!
Old 05-23-2012, 10:41 PM   #4 (permalink)
That's messed up!
I used to know a guy that would heat his lamp in the oven and pull of the lens. He would sit it out to dry in the oven on very low heat and then silicone it all back together... No more moisture!
Old 06-22-2012, 12:04 AM   #5 (permalink)
I know someone who does that too but on a Honda Accord for a black housing. Have to be very carefull to do that, not for me lol
Old 06-24-2012, 12:27 PM   #6 (permalink)
tallbump is on a distinguished road
One of my headlights is like that too. But no warranty.
I know plenty of people who have done the oven thing on Bonnevilles butg I have never tried it
Sent from my LG-VM701 using Tapatalk
1998 Pontiac Bonneville SE with about 152,000 on the clock
2005 Equinox LS AWD with about 95K
tallbump is offline   Reply With Quote
Old 07-03-2012, 04:45 PM   #7 (permalink)
08PILOT's Avatar
Both mine do it a lil after I wash it, but the HID's dry them out fast
Old 08-31-2012, 10:52 AM   #8 (permalink)
ReggieBee is on a distinguished road
Default equinox headlight
Hi, What happens with these headlights is the automatic on lights are on for such a long period of time that it ages the headlight assembly faster then normal. All cars that are weathered over the years will have condensation and or fading problems, but with equinox it starts early. The automatic lights
cause so much heat that in a small amount on time the headlight lenses start
to get small hair line cracks in them that cannot be fixed you will have to buy new headlight lenses and remove the auto on light relay which is located under the hood so that the lights only turn on at night and your lense will have a longer life span. If you take the headlight off and air dry it then reseal it then put water on it (pressure) or run it threw the car wash you will see that the condensation comes back. Theres nothing wrong with the seal, its the excual lense. Well I have a passenger side lens for sale brand new for $100. Hope this helps.
ReggieBee is offline   Reply With Quote
Old 12-23-2012, 03:15 AM   #9 (permalink)
Ralphwhite is on a distinguished road
As if it is a recall I have not a clue. But what I can tell led lighting you is that the dealer has changed my headlights for moisture in them. I have read it was a recurring problem so it may help some of you out with water in your headlights if you are still within warranty or know someone at a dealer.
You need to change those lights as they are of no use now.
Ralphwhite is offline   Reply With Quote
Old 02-20-2013, 11:48 AM   #10 (permalink)
SalsaNox is on a distinguished road
I dont know how much truth to this, but for those that are out of warranty, (& cannot afford new headlights) I was told that if you drill small holes under or behind the housing, it creates a vent & avoids the condensation... *Again, I dont know if its true... don't go drilling unless you're sure; I wont be held responsible for any errors in driling the housing.
SalsaNox is offline   Reply With Quote
Old 02-28-2013, 12:57 PM   #11 (permalink)
1ATony's Avatar
1ATony is on a distinguished road
Check the seals on the bulbs, if they are worn out you may want to replace the headlight bulbs.
1ATony is offline   Reply With Quote
Old 08-08-2013, 04:40 PM   #12 (permalink)
skippy588 is on a distinguished road
I have the same issue with my 2007 Equinox
skippy588 is offline   Reply With Quote
Old 03-17-2014, 02:58 PM   #13 (permalink)
reeves95 is on a distinguished road
I have had this in both headlights. It is a seal issue according to mechanic. Easy fix was to drill small holes in bottom of lens and let water drain out and air in....Headlights after 6 years look 'dirty' but i'm not ready to fork out lots of money for the assembly yet. It's not a recall b/c it really doesn't affect performance of car and isn't 'dangerous' I'ev had to replace the bulbs in each headlight twice now
reeves95 is offline   Reply With Quote
Old 03-18-2014, 12:48 PM   #14 (permalink)
Moisture can def reduce the life of your bulb. I wouldn't recomment drilling holes in the lamp housing tho, because once you have a hole there moisture can continue to get into the housing. Especially if you live in a Wet/Humid climate
I would
A. Make sure there are no cracks in the housing
B: Take the lamp out remove the bulbs and allow the housing to dry out.
C. Check the seal on the bulbs (may need cleaned or new bulbs with new seals)
D. (I did this with an older car and it worked well) Using Silicon on the exisiting seal. Or Follow some of the youtube videos out there that so how to heat the housing up to take apart and reseal.
Good Luck!
Old 06-03-2014, 11:43 PM   #15 (permalink)
Kevin is on a distinguished road
I ended up pulling mine out n baking it n pulling it apart n drying it out n painting it n put it bak together with black gasket seal n hasn't condensate yet, been bout 3 months
TheDarkKnightKnox likes this.
Kevin is offline   Reply With Quote
moisture in headlights, water in head lights
Old Nox headlights prheaume Exterior Modifications 58 04-20-2012 04:24 PM
DRL's/ Auto headlights Lenn 05-09 Equinox General Forum 4 08-09-2011 08:42 PM
