-   Detailing Tips and Tricks (http://www.chevyequinoxforum.com/f38/)
-   -   problem after cleaning water spots (http://www.chevyequinoxforum.com/f38/problem-after-cleaning-water-spots-1388/)
tns58 07-13-2015 07:11 PM
Need help/advice please. I have a black 2012 Equinox just bought used and after first wash, had water spots that would not come off. Someone suggested dilute white vinegar and spray and wipe. I used 4 oz. of white vinegar to 28oz. of water and used a microfiber towel to wipe off quickly, and then another clean microfiber towel to wipe again. tried on the hood and it took off the water spots, but a few mins. later I noticed tiny white specs on the hood. You could kind of scrape some off with your fingernail. Hood also looks duller now. Is this wax coming off? What do I need to do next? Apply wax or cleaner? Clay bar and then wax? The solution should have been safe at this dilution and it did not stay on very long. Did I screw up bad? Appreciate your input.
3fingers 09-10-2015 12:07 AM
Hmm clay the paint and polishing it should remove it and restore its finish.
equilover 09-10-2015 09:49 AM
I use Meguiar's A3714 Compound Water Spot Remover. Got mine from Amazon. It's effective.
dietz4ibanez 09-10-2015 10:23 AM
It might be a little pricey but I use this stuff that you can use after a wash called EZdetailer, it's around $15 a can but one can us good for 3-5 vehicles.
EZ WAX 579221 Premium EZ Detailer Waterless Cleaning Spray Wax - Rakuten.com
If your car is dusty you can use it to wash your vehicle but if it's muddy better get that thing pre-washed. It's a wax on, wax off formula. You can use it on windows and everywhere else, it'll also buff out some scratches while you buff it by hand.
Once you wipe it in, you'll notice the haze, spray sparingly throughout the entire body the vehicle. Go back again with a new towel and wipe away the haze. It be the best your vehicle looks after a wash/wax.
EQui 10-03-2017 11:37 PM
I'm having the same problem too. Will take note of the suggestions.
Richard_Stanfield 04-20-2018 07:34 AM
Thanks for sharing knowledge its really helpful thread.
avengers3infinity_war_ful 04-22-2018 05:37 PM
avengers3infinity war full movie 2018
https://avengersinfinitywarmovieonline.com/
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
