Recently I've been having some intermittent trouble starting my 2008 Chevy Equinox LS. The problem only occurs when I leave my daughter's daycare after dropping her off in the morning...so it's the second start of the day, after about a 5 minute drive. All other times the car starts fine. Here's a rundown of the symptoms:
-May 9th or 10th: I tried starting the car (at the daycare) and the engine made sort of a buzzer sound, and didn't start. Then, after a few seconds, I tried it again and it started right up.
-May 11th: I did some interstate driving (about a 1.5 hour trip each way). On the trip up, after about an hour or so, I received the following warnings: "Service Traction Control" and "Service Stabilitrack." After I turned off the car the warnings have never come back on (I have no idea if this is related to the starting problem, but figured I would mention it - any advice on this issue independently would also be greatly appreciated).
-May 18th: while sitting at a stoplight, the car was idling roughly - I had to really hold down the brake to prevent the car from lurching forward, and the RPMs were going between about 800 and 1500...haven't noticed any rough idling since, though.
-May 20-24 & 27-29: Again, when leaving the daycare in the morning, when I try to start the car, it sounds like a machine gun. It usually won't start the first time, but will the second time after still making that noise. Here's a video of this, I hope it helps: video. The odd thing, though, is that it hasn't done it the last two times I've left the daycare (I doubt the problem just fixed itself, but I have no idea).
Thanks for any help or suggestions you can offer!
