starter problem
This is a discussion on starter problem within the 05-09 Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
I have a 06 nox replaced 3 starters after replacing when I start nox it makes noise like switch is ...
Old 05-18-2014, 09:53 AM   #1 (permalink)
noxmadmax is on a distinguished road
Default starter problem
I have a 06 nox replaced 3 starters after replacing when I start nox it makes noise like switch is stuck and keeps trying to start nox. Does this a few times then starts normal. Then every once in awhile does it again then starter goes out. Can someone help.
noxmadmax is offline   Reply With Quote
Old 08-21-2014, 07:28 PM   #2 (permalink)
vtbigdog is on a distinguished road
Check the battery connections. Its possible that you have a bad connection or your battery is weak and needs to be replaced. You can have the battery tested as well.
vtbigdog is offline   Reply With Quote
crazy electrical problem HeavyMetalNox 05-09 Equinox Maintenance 4 05-23-2015 09:15 PM
P0404 EGR Problem atomicfire 05-09 Equinox Maintenance 1 03-23-2014 09:12 AM
Just another problem Lew2156 05-09 Equinox General Forum 2 03-19-2013 02:58 PM
2010 nox hid problem ponczek 2010+ Equinox General Forum 1 01-11-2011 08:14 PM
