-   -   starter problem (http://www.chevyequinoxforum.com/f37/starter-problem-1154/)
noxmadmax 05-18-2014 09:53 AM
starter problem
I have a 06 nox replaced 3 starters after replacing when I start nox it makes noise like switch is stuck and keeps trying to start nox. Does this a few times then starts normal. Then every once in awhile does it again then starter goes out. Can someone help.
vtbigdog 08-21-2014 07:28 PM
Check the battery connections. Its possible that you have a bad connection or your battery is weak and needs to be replaced. You can have the battery tested as well.
