RPM's surging at idle after head gasket job
This is a discussion on RPM's surging at idle after head gasket job within the 05-09 Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
05 Equinox. Did a head gasket job and everything went smoothly. Started it up when finished and it ran fine. ...
Old 05-28-2014, 08:27 PM   #1 (permalink)
rft607 is on a distinguished road
Default RPM's surging at idle after head gasket job
05 Equinox. Did a head gasket job and everything went smoothly. Started it up when finished and it ran fine. After reaching operating temperature, the RPM's will start to surge until it stalls. It starts right back up and will happen again a few minutes later. No codes present and it's smoking out of exhaust still, only not as bad and it doesn't smell like coolant. Smells more like it's running rich. Also seems to be a slight backfire when I rev the engine. Any help is greatly appreciated, thanks.
rft607 is offline   Reply With Quote
Old 07-10-2014, 08:13 PM   #2 (permalink)
vtbigdog is on a distinguished road
What color is the smoke?
White = Head Gasket leak
Black = Rich Mixture
vtbigdog is offline   Reply With Quote
Old 07-27-2014, 09:25 PM   #3 (permalink)
3fingers is on a distinguished road
To add;
Blue = Burning oil.
3fingers is offline   Reply With Quote
Old 07-29-2014, 08:53 PM   #4 (permalink)
Make sure to have a leak down and compression test to have an idea of your engines health.
Old 08-04-2014, 12:20 PM   #5 (permalink)
ThePapaJohn is on a distinguished road
Still having your problem?
Compression check should always be performed pre and post head gasket work. Find out if your introducing an issue or bringing to light a previous minor one....
ThePapaJohn
2007 Chevy Equinox LS
Plain base model - Black
ThePapaJohn is offline   Reply With Quote
Old 11-30-2015, 02:30 AM   #6 (permalink)
Shane is on a distinguished road
Did u ever resolve the problem? I just did a 2005's head gaskets and have the identical problem? Please advise
Shane is offline   Reply With Quote
Head Light Question per00002 Exterior Modifications 0 03-11-2013 08:43 PM
06 equinox rough idle at startup only [email protected] 05-09 Equinox General Forum 5 09-10-2012 03:45 PM
Coolant/gasket woes? tallbump 2010+ Equinox Maintenance 5 04-20-2012 06:29 AM
2010 nox rough idle jherman 2010+ Equinox General Forum 4 04-13-2012 11:40 PM
I have sirens in my head. Z_Ghost Off-Topic Videos 10 11-04-2011 07:53 PM
