P0404, P0406, and Stalling After Changing EGR Valve
This is a discussion on P0404, P0406, and Stalling After Changing EGR Valve within the 05-09 Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
Hello, I have a 2005 Chevy Equinox with the 3.4 engine. It was overheating at low RPMs but would go ...
Old 11-18-2016, 07:31 PM   #1 (permalink)
michaellong is on a distinguished road
Default P0404, P0406, and Stalling After Changing EGR Valve
Hello,
I have a 2005 Chevy Equinox with the 3.4 engine. It was overheating at low RPMs but would go back to normal operating temperature if rev'd to a high RPM even if the car was sitting still in park. The car also ran rough until it warmed up and was also hard to start when cold. I replaced the EGR valve but it looks like I got an updated one and needed to get the updated EGR tube. Once that was done, I realized that the electrical EGR valve connectors are different. While they do fit, the part of the connector that latches onto the valve is on the wrong side. The car also stalls if I reset the CEL lights. However, if I let them come back, the car does not stall. It seems like the computer is compensating for something, which is why it stops stalling. I have cleaned the throttle body, which had a lot of gunk in it and cleaned the MAF sensor with the proper cleaners. The car now starts well and idles well with the new EGR valve. I just get a p0404 and p0406 code. Can you guys give me some more information on the updated EGR valves? Do I need to get a new connector and solder it on?
michaellong is offline   Reply With Quote
Update EGR Valve Equinox LT 2005 jrcygcm 05-09 Equinox General Forum 1 08-03-2017 07:30 PM
P0404 EGR Problem atomicfire 05-09 Equinox Maintenance 1 03-23-2014 09:12 AM
PCV Valve Location DVB1 05-09 Equinox General Forum 2 01-11-2014 10:10 AM
Changing from dino to synthetic oil jherman 2010+ Equinox Maintenance 3 09-26-2013 09:27 PM
Purge valve papabearpaul 05-09 Equinox General Forum 0 02-20-2013 12:21 PM
