Coolant Leak Near Belt Tensioner
This is a discussion on Coolant Leak Near Belt Tensioner within the 05-09 Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
On my '05 LT AWD I have been trying to trace a coolant leak that keeps draining the tank near ...
Old 05-28-2013, 08:43 PM   #1 (permalink)
equalknocks is on a distinguished road
Default Coolant Leak Near Belt Tensioner
On my '05 LT AWD I have been trying to trace a coolant leak that keeps draining the tank near the battery. I can't find any evidence of a leak from the head gaskets or manifold gaskets, at least as far as I can see with a flaslight and mirror from underneath or above. I can see a wet streak coming from the bolt just behind the belt tensioner pulley a little toward the engine center line, as the engine cools down this streak migrates down to become a slow drip coming off the front of the oil pan. This bolt seems to be part of an assembly that houses the water pump, and also attaches to one of the motor mounts. I have read that this might be the timing cover. Has anyone ever seen a leak in this area, and how much work is it to fix?
equalknocks is offline   Reply With Quote
Old 11-04-2013, 04:27 PM   #2 (permalink)
Did you ever get this figured out? I hope there was a easy solution.
Coolant flush/ radiator issues...? cezardob 05-09 Equinox Maintenance 9 02-04-2017 09:22 PM
Help oil leak! SalsaNox 05-09 Equinox General Forum 3 06-24-2013 05:43 AM
driver seat belt locked - looking for a locksmith sypatnode 05-09 Equinox General Forum 0 02-21-2013 12:52 AM
Coolant/gasket woes? tallbump 2010+ Equinox Maintenance 5 04-20-2012 06:29 AM
Ac Condensor Leak. SPH01 2010+ Equinox General Forum 12 02-09-2011 12:34 PM
