Blower problems
This is a discussion on Blower problems within the 05-09 Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
If anyone could help, I would appreciate it big time. I thought my '06 nox blower had failed so I ...
  • 1 Post By equilover
Old 11-18-2011, 11:58 PM   #1 (permalink)
Jaws is on a distinguished road
Default Blower problems
If anyone could help, I would appreciate it big time. I thought my '06 nox blower had failed so I replaced it. I had the same result with the new blower.... No power. So I replaced the resistor and still nothing. I decided to check the voltage at the switch. The meter read 6 volts for all speeds and at the blower the voltage read the same also. Why doesn't the blower work at all? What do I test next? Is the visit to the dealer the next step? I'd appreciate any feedback, thanks.
Sent from my DROIDX using Tapatalk
Jaws is offline   Reply With Quote
Old 11-19-2011, 12:08 AM   #2 (permalink)
I would check the wiring harness plug ins to make sure they do not need to be replaces..
I have a 2005 2500hd work truck that the blower stopped working. The resistor and connectors needed to be replaced.
Old 11-19-2011, 11:04 AM   #3 (permalink)
Check for a voltage lost on the harness. Check also if you have a ground on the blower.
Old 12-11-2011, 11:32 AM   #4 (permalink)
All fixed now! It happened to be a burnt wire in the harness behind the drivers side trim. Glad to have heat again, yay!
Old 12-11-2011, 03:34 PM   #5 (permalink)
Awesome! Glad that it is fixed!
Old 10-15-2015, 11:42 PM   #6 (permalink)
debbyb71 is on a distinguished road
Moms 06 does nothing when dial for low/high is turned on - thanks for your posts now I know what to look for . any suggestions on what to try first?
Sent from my XT1056 using Tapatalk
debbyb71 is offline   Reply With Quote
Old 10-20-2015, 07:59 AM   #7 (permalink)
Default Blower
I would suggest that you go check the blower resistor first.
debbyb71 likes this.
Old 11-17-2015, 08:07 PM   #8 (permalink)
Sorry it took so long to get back with the solution - you were right it was the resistor
Sent from my SPH-L710 using Tapatalk
Old 11-17-2015, 08:09 PM   #9 (permalink)
Old 12-12-2015, 04:09 PM   #10 (permalink)
Blower stopped working again. Haven't tore into it yet to see if its the same as before like pic of melted resistor. what would cause it to do it? Any thoughts? Thanks for the help
Is anyone having problems with their 2011? DeeDee1202 2010+ Equinox General Forum 9 01-04-2016 11:26 AM
Starting problems, gas smell, shifting issues.. Helene74 2010+ Equinox Maintenance 13 05-22-2012 08:25 AM
2010 Equinox battery problems rbiggers 2010+ Equinox General Forum 21 02-05-2012 03:42 AM
2011 Equinox problems since purchase equiowner 2010+ Equinox General Forum 4 08-07-2011 04:34 AM
