Ball Joint
This is a discussion on Ball Joint within the 05-09 Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
i had to take off steering knuckle to remove what's looks to be original hub on a '05 when I ...
Old 03-22-2015, 09:34 AM   #1 (permalink)
BionicBo is on a distinguished road
Default Ball Joint
i had to take off steering knuckle to remove what's looks to be original hub on a '05 when I used a pickle fork to pop the lower ball joint (which looked original aswell) I noticed the clearish grease starting to leak I don't see any damage to boot so I don't know if I wrecked it but I was thinking of replacing just in case, my question is are they pressed in or should it pop out easy enough once I drill out the rivets, I don't want drill out if I'm not going to be able to remove it from control arm.
BionicBo is offline   Reply With Quote
Old 03-25-2015, 03:46 PM   #2 (permalink)
Found my answer just went ahead and did it, very easy
Old 03-27-2015, 11:40 PM   #3 (permalink)
Nice! I had a hub in a Saturn Vue that was so rusted that I had to take the control arm somewhere to have it pressed.
How To Install Replace Front CV Axle Joint Chevy Equinox Saturn Vue 05-10 1AAuto.com 1ATony The Official "How To:" Section 0 04-12-2013 11:33 AM
