another front end rattle
This is a discussion on another front end rattle within the 05-09 Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
i checked the steering column knuckle but i really feel like the vibration "drum" sound is coming from both front ...
Old 08-26-2018, 11:38 AM   #1 (permalink)
cavell is on a distinguished road
Default another front end rattle
i checked the steering column knuckle but i really feel like the vibration "drum" sound is coming from both front wheels. an expansion joint makes the front end sort of hum/drum or drone? not a clunk or knock. yes i read about the rear control arm bushings but they both look good with a bit of prodding with a pry bar. new struts might help? strut mounts? subframe bushings?
cavell is offline   Reply With Quote
Old 09-08-2018, 08:31 AM   #2 (permalink)
pretty sure some of it is from the steering column knuckle. i tried tweaking the knuckle/bolt under the dash and no luck. maybe a different shaft from a junkyard nox might help? they are 60 or so online.
Old 09-29-2018, 09:57 AM   #3 (permalink)
ordered new struts. will see if it makes any diff in ride. noise. rattle. quiver.
Rattle in engine area 2018 Nox Micah 2010+ Equinox General Forum 0 02-09-2018 04:30 PM
Equinox 3.0 V6 rattle Masterkevj 2010+ Equinox General Forum 7 05-17-2016 12:12 PM
Rattle Noise Front End BionicBo 05-09 Equinox Maintenance 4 09-10-2015 08:47 AM
Rattle in front end elilko 2010+ Equinox Maintenance 1 09-03-2015 07:42 AM
Seat Rattle/Squeak? jwill_213 2010+ Equinox General Forum 4 06-13-2011 03:05 PM
