2007 Equinox Stabilitrak Message w/codes
This is a discussion on 2007 Equinox Stabilitrak Message w/codes within the 05-09 Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
I had the "Service Stabilitrak" and "Service Traction Control" message come up but that was it, no performance issues. So ...
Old 09-05-2017, 01:16 PM   #1 (permalink)
sam_moening is on a distinguished road
Default 2007 Equinox Stabilitrak Message w/codes
I had the "Service Stabilitrak" and "Service Traction Control" message come up but that was it, no performance issues. So I waited till a check engine code popped up and these are the codes that came up.
These were what Advance Auto said
C0561 - System disabled Information Stored invalid serial data recieved - invalid serial data recieved.
P1779 - Torque Delivered Signal
P0404 - Exhaust gas recirculation conteo circuit range/ performance (in the top right corner it says ECM)
P0404 - same description as abovebut in the top right it says Mod $00
Took it to O'Reillys also and this was the one code that showed up different
U0073 - Control module communication bus off
So I changed out the EGR valve hoping all these problems stemmed from that and pulled the cables to the battery to try and reset the codes. Started it and drove about 30 miles and the code was gone and then they popped back up with the check engine light/codes and the "Service Stabilitrak" message.
Anyone have any thoughts on where I can go from here. I drove it for probably 75 miles more and nothing seems to be running wrong.
Thanks in advance
Sam
sam_moening is offline   Reply With Quote
Old 09-20-2017, 10:44 PM   #2 (permalink)
I got this for a while, also changed EGR valve and everything... got rid of it by replacing a wheel speed sensor that was bad. I noticed that when I plugged a scanner and watch for the speed of each ones
code, egr, equinox, stabilitrack
power steering message bawbeebee 2010+ Equinox General Forum 4 10-19-2017 09:34 PM
2010 Equinox p0324 &p0326 codes ziggenpuss 2010+ Equinox Maintenance 0 06-17-2015 07:35 PM
Service Stabilitrak/Stabilitrak off bchestnut 05-09 Equinox Maintenance 0 05-08-2015 12:47 AM
Navigation System Error Message HalleCat 05-09 Equinox General Forum 1 03-26-2015 12:45 PM
2011 Equinox LT MIL, limp mode, service stabilitrak Babsmitty 2010+ Equinox Maintenance 2 01-21-2015 04:27 PM
