07 Equinox - Losing Power, Tach drops to 0
This is a discussion on 07 Equinox - Losing Power, Tach drops to 0 within the 05-09 Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
2007 Equinox LT, 3.4L V6, 125K miles. A few months ago, I replaced my left front axle shaft as the ...
Old 01-17-2016, 01:40 PM   #1 (permalink)
JohnnyThrowback72 is on a distinguished road
Default 07 Equinox - Losing Power, Tach drops to 0
A few months ago, I replaced my left front axle shaft as the boot had cracked. In doing so I broke a transmission seal and lost some fluid. I made an appointment with the dealer to have the transmission looked at a few days later. Before the appointment, I noticed that while driving with the engine still "cold", my tachometer would waver and suddenly drop to 0; the car remained running, but I lost almost all acceleration. I had to pull over and restart the car (which took a few tries) before I could get back on the road.
I notified the dealer about this and while they repaired the seal and replaced my transmission fluid, they could not replicate the power loss I was experiencing.
Since then, I having been having this issue every time I drive the car. The only difference appears to be when I warm up the engine until the temperature indicator is nearly at the halfway mark - if I then drive, I don't seem to have the problem.
Then just this week, the check engine light came on. I pulled the following codes:
P0336 (Crankshaft position sensor range / Performance)
P0327 (Knock Sensor Circuit Low Input)
My DIY experience is limited with respect to drivetrain, so any guidance anyone can provide on the above codes and whether the current issues I'm facing are related to these codes would be helpful.
Thanks in advance.
JohnnyThrowback72 is offline   Reply With Quote
p0327, p0336, power, stall, tachometer
2010 Equinox V6/LT/AWD Power Steering Out billyi1 2010+ Equinox General Forum 2 11-08-2015 09:43 PM
07 tach, fuel gauge, low heat, turnsignals jerryotis 05-09 Equinox General Forum 1 03-17-2015 10:04 PM
2010 Chevy Equinox v6 3.0 Reduced Engine Power/Replace Stabiltrack dietz4ibanez Engine & Performance Modifications 6 07-08-2014 06:01 PM
How To Install Replace Power Window Motor Chevy Equinox 05-09 1AAuto.com 1ATony The Official "How To:" Section 0 04-12-2013 11:32 AM
Need power foldaway mirrors for 09 Equinox Sport 09_Equinox Exterior Modifications 6 05-01-2012 08:49 AM
