07 AWD Equinox Tran stuck in N, but shifter free
This is a discussion on 07 AWD Equinox Tran stuck in N, but shifter free within the 05-09 Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
The past week or two I've noticed after driving my car, whenever I would go to put it into park ...
Old 10-26-2019, 03:13 PM   #1 (permalink)
Root10 is on a distinguished road
Default 07 AWD Equinox Tran stuck in N, but shifter free
The past week or two I've noticed after driving my car, whenever I would go to put it into park the shifter would stop before passing Reverse even with the brake on and shifter button pressed in. However if I dropped the shifter back down to L then back up I could then put it in park. Problem Solved right? Nope!*
Today first thing this morning, same exact thing happens. It sticks at Reverse so I drop it down to L then as I bring it up into park the shifter continues fine into P but I notice the light on the dash and the light on the shift bezel is stuck at Neutral. However my shifter is completely free, I still have press the button on the shifter but that's it.*
I've had this happen on normal GM transmissions and its normally the bushing that connects the shift cable to the transmission shifter dry rotted, but this transmission from what I've seen is certainly not the same! Does anyone have any idea what I may be looking at here? I'm kind of at a lost. Its a 2007 Chevy Equinox LT, AWD 3.6L, with 120k miles. Any help would be a great help guys!
Root
Root10 is offline   Reply With Quote
Stuck key bjh063 2010+ Equinox General Forum 0 12-24-2018 01:02 AM
2006 equinox stuck on vents I need defrost Joshuaboyle 05-09 Equinox General Forum 0 11-10-2018 11:16 PM
Key Stuck in ignition! Help! PLZ! TX14nox 2010+ Equinox Maintenance 1 09-05-2018 08:31 AM
2018 Equinox Shifter Cable jsfb6pts 2010+ Equinox General Forum 10 05-31-2017 09:04 AM
2013 Equinox LT Shifter / Gear selector light bulb out jsupreme23 2010+ Equinox General Forum 0 03-05-2016 06:51 PM
