Problems replacing the engine
This is a discussion on Problems replacing the engine within the 05-09 Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
Afternoon everyone, I have something of an interesting problem. Recently my 05 equinox lost a piston and ate it self. ...
Old 06-29-2014, 07:07 PM   #1 (permalink)
clanmccracken is on a distinguished road
Default Problems replacing the engine
Afternoon everyone,
I have something of an interesting problem. Recently my 05 equinox lost a piston and ate it self. Extended warrenty wouldn't cover the payment because I went 4125 miles without an oil change. Anyway, Because I am still paying off the car I decided to replace the engine with a certified used 2008 3.4L motor from the local GM dealership. We get the old motor out without many difficulties (other then the oil pan) and put the 2008 motor in.
We get everything together, all the connections, and try to turn the key. The motor cranks but wont turn over. We have pressure on the fuel line, the spark pugs and the fuses are all new. After some troubleshooting we find that the spark plugs are not firing. We hook up a scanner to the computer and it spits a few codes at us. C0276 is the only one we cant clear, but the others (Camshaft sensor No signal, crackshaft sensor No signal) come back every time we try to start the engine.
We've replaced both the cam shaft and the crank shaft sensors. The sensors are both getting voltage to the sensors, so we know there isn't an open in the harness. Is there some difference between the 2005 and the 2008 Equinox motor that would cause a 2005 ECU to error out when hooked to a 2008 motor?
Any light you can shed on this problem would be of great help.
Eric
clanmccracken is offline   Reply With Quote
Old 07-08-2014, 06:07 PM   #2 (permalink)
Any update on this?
Old 07-23-2014, 07:20 PM   #3 (permalink)
ThePapaJohn is on a distinguished road
Question
Originally Posted by dietz4ibanez View Post
Any update on this?
Really, would like to know if there is an update!!
ThePapaJohn
2007 Chevy Equinox LS
Plain base model - Black
ThePapaJohn is offline   Reply With Quote
Cleaning Engine Compartment rbiggers Detailing Tips and Tricks 28 11-04-2013 08:04 PM
Engine cover oil stain Jiftim 2010+ Equinox Maintenance 3 11-01-2013 08:25 PM
Engine Burning Oil ferg 2010+ Equinox General Forum 3 09-02-2013 09:29 AM
Replacing 08 (3.4) Condensor? Dave00 2010+ Equinox General Forum 9 06-22-2011 09:24 PM
Replacing 08 (3.4) Condensor? Dave00 2010+ Equinox Maintenance 2 06-08-2011 10:54 PM
