No Power and ABS.
This is a discussion on No Power and ABS. within the 05-09 Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
I'm having a couple of issues with my 07 Equinox AWD. During the 1st 5 minutes of driving or when ...
Old 08-17-2017, 01:40 PM   #1 (permalink)
KG1
KG1 is on a distinguished road
Default No Power and ABS.
I'm having a couple of issues with my 07 Equinox AWD. During the 1st 5 minutes of driving or when "punching" it, the engine will stumble, the tach will read only 0, the tranny works in L and D. I can continue to drive it by shifting to L at each stop and upshifting at some point to D. If I stop and turn the engine off for a couple of minutes everything resets and it will run normal again. At least until I try to "punch" it again. When this happens I get service stabilitrak, starbilitrak off and tracktion control off and service traction control messages on the display. 90% of the time the check engine light does not come on. The other 10% I get a P0336 code which points to the crankshaft position sensor. replacing the sensor is relatively easy except for the relearn procedure that is done afterwards which websites say requires a two way scan tool which I don't have. Is there any way to do this manually?
KG1 is offline   Reply With Quote
power steering message bawbeebee 2010+ Equinox General Forum 4 10-19-2017 09:34 PM
disable constant power to DC ikeeki320 05-09 Equinox General Forum 2 03-21-2017 01:37 AM
Power locks JimSTL The Official "How To:" Section 3 12-10-2015 09:46 PM
power steering electrical dcpophb 05-09 Equinox Maintenance 0 09-30-2015 12:37 AM
T10 High Power LED Light homauto Engine & Performance Modifications 1 09-09-2015 11:03 PM
