Hi folks! '08 Sport owner
This is a discussion on Hi folks! '08 Sport owner within the 05-09 Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
New here, but had some questions. We picked up a used '08 Equinox Sport in October '12 with 39K on ...
Old 10-15-2013, 10:20 AM   #1 (permalink)
Black08Sport is on a distinguished road
Default Hi folks! '08 Sport owner
New here, but had some questions. We picked up a used '08 Equinox Sport in October '12 with 39K on it and were pretty happy with it for about a week. It immediately began squealing when turning and I took it in to a local dealer (a different dealer than where I bought it). He called a little later and said that it needed a steering gear but the car was out of warranty. Additionally, he said it needed two new tires, new rotors, and new pads. He said if I'd do the tires, rotors and pads through him he'd lobby GM to cover the steering gear. I agreed and all that was done less than 12 months ago.
Fast forward to today, where it's back at the dealer with 52K on it and with severe shaking in the wheel when braking. I suspected and had Meineke confirm last week that the rotor is warped - they suggested taking it back to the dealer to get them to hopefully handle it under warranty. The dealer is being very coy about taking care of it unless it's defective. I've put 12K miles on these rotors (90% highway) and it's not like I'm autocrossing it to destroy the brakes. Now I'm potentially looking at turning year-old rotors that will probably only survive one to two cuts before needing replacement again.
All this history aside, is this what I should expect from owning this vehicle? My cost of ownership so far has been significant and I wonder if it will continue.
Black08Sport is offline   Reply With Quote
Old 10-15-2013, 08:17 PM   #2 (permalink)
Sounds like the dealer over torqued the lug nuts. I turned the rotors on my equinox around 60k miles. If someone else touches my lug nuts, I always loosen them and retorque them to spec.
If its warped after 12k milesthe dealer needs to push warped rotors with free replacement or turn down the rotors.
If you have the original invoice of the work done and if it doesn't say that they torques the lugs you can tell them they didn't and blame them for over tightening the lugs. If it doesn't specify the foot pounds and specifics for each wheel, they can't prove otherwise.
Old 10-15-2013, 09:07 PM   #3 (permalink)
mswerb's Avatar
Was it NOT a certified used car? With that few miles I wouldn't see why it would not be. Hopefully the dealership that last serviced it will take care of you. As stated above, if you have the original invoice for service, take it back and see if they will be reasonable with you.
Old 10-16-2013, 01:40 PM   #4 (permalink)
No luck...they turned them after saying they found nothing defective and charged me $75 + $25 for balancing the tires. I also was supposed to receive a 27 point inspection and free car wash. The car wasn't washed, and my TPMS showed I had a tire 2 lbs low this morning. I'll avoid these guys like the plague going forward.
FYI, it was this dealer that did my last tire rotation less than 4K ago, so they torqued the lugs on it. I guess the torque specs are just a suggestion......
Old 10-16-2013, 05:23 PM   #5 (permalink)
mswerb's Avatar
Good thing they didn't wash it. Automatic dealership carwashes will jack up your ride.
Old 10-16-2013, 08:21 PM   #6 (permalink)
Default Re: Hi folks! '08 Sport owner
That sucks. Just keep in mind that the reason for torquing lug nuts is to ensure that they are evenly tightened. If you have one lug nut that is torqued and the next in order clockwise is over torqued, this can cause rotor warpage.
I hope that helps!
08 nox sport which oil for transmission change? ogoz23 05-09 Equinox Maintenance 3 11-11-2013 08:57 PM
Looking to purchase Nox Sport very soon!! ls2legit 05-09 Equinox General Forum 3 11-04-2013 04:17 PM
Goodbye Equinox Sport... 1sLoY7 05-09 Equinox General Forum 6 10-15-2013 12:06 PM
2008 Chevy Nox Sport owner in the house! *UPDATED POST #1 WITH PHOTOS Chevygirl32 New Member Introduction 37 02-27-2012 04:06 PM
Sport Spoiler 08PILOT 05-09 Equinox Maintenance 9 12-31-2011 11:01 AM
