Equinox Camshaft Replacement
This is a discussion on Equinox Camshaft Replacement within the 05-09 Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
Old 08-06-2014, 01:51 AM   #1 (permalink)
beigmatt is on a distinguished road
Default Equinox Camshaft Replacement
I have a stock 3400 LNJ. It produces 185 hp (138 kW) and 210 lbft (285 Nm).
My transmission is an Aisin AF33 that has a gearbox limit of 243 ftlbf (329 Nm) of torque.
I have been considering a few options to get a torque/HP increase. I would have loved to supercharge my 3400 but I cant afford a new tranny. Looks like a 20-30lb torque increase will have to suffice. I have considered porting/polishing my heads or a 3500 head swap.
Computer adjustments are NOT necessary with a new camshaft (so I have been told)? Basically I am looking for help to properly remove my old camshaft and install the new one. While I have the engine open are there any other parts I should consider replacing? Valves? Lifters? Head gasket? (my previous engine had a had gasket issue, among other things, leading to a tick, then blowing 6 months later despite all my efforts, hense my newer engine, that I have been treating very very well so I can do something like this).
If somebody has anything even close to a step-by-step guide it would mean the world. I guess this would be my first "engine job". I have a torque wrench and angle gauge for the cylinder head bolts.
Are there any other parts besides the cylinder head bolts I should consider replacing while I am at it? Head gasket? Valves? Lifters? (hydraulic, switch to anything else??), new timing chain? (and ofcourse new Comp Cams 26986 Valve Springs)
I am not trying to push crazy power out of the engine, I am purchasing the torque/MPG cam to help move the extra weight of my equinox. This is all for a learning experience. The fact that I can do it for $500-$600 is more appealing then trying to piece all of the parts together for a 3500 swap and have random parts and adapters.
If anybody has a better idea to get 20-30lbs of torque that is easier then a camshaft swap, I am all for it. I figure a camshaft swap is a nice step-by-step guide towards getting to know the inside of my engine, because I love every other bit of my car.
NOTE: this is my daily driver, so I need to do the job right. I will post pics and keep you updated, I need some input before I move forward with the job. All help appreciated
beigmatt is offline   Reply With Quote
05 equinox, camshaft replacement, engine
Replacement WiperBlades?? 2010BlkGraniteNox 2010+ Equinox Maintenance 55 12-13-2018 01:07 PM
O2 Sensor Replacement DVB1 05-09 Equinox Maintenance 0 02-12-2014 12:01 PM
AC Lamps replacement oleg1981 The Official "How To:" Section 5 03-10-2013 11:02 PM
equinox wiperblade replacement deand New Member Introduction 1 01-28-2013 04:48 PM
program a replacement key transponder achtung3945 The Official "How To:" Section 4 12-05-2011 04:09 PM
