Brake problems
This is a discussion on Brake problems within the 05-09 Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
Ok to keep this short and sweet: replaced all rotors, drums, and pads/shoes. Replaced rear passenger drum again. First replacement ...
Old 07-01-2015, 03:05 PM   #1 (permalink)
Mastergunner82 is on a distinguished road
Default Brake problems
Replaced rear passenger drum again. First replacement was horribly out of round.
Next I did a test drive. Returned home to find smoking front passenger brake. Replaced the rotor (again) and put a new caliper and pads on.
Bled the brakes. Front passenger brakes apparently still grabbing.
I would rather not test drive again for fear of destroying another ABS sensor which melted last time.
Need advice.
Mastergunner82 is offline   Reply With Quote
Old 07-06-2015, 01:07 PM   #2 (permalink)
jdpete is on a distinguished road
Since you replaced the calipers that rules them out. Did you check the caliper pins? I've seen problems also with the brake lines. The rubber line between were the steel line ends and the caliper can get kinked to were it allows fluid through but will not let any fluid back so pressure won't be relieved. Sometimes the way the pads are wearing could hint at the problem. If the piston side pad is worn down more, it could be a problem with the line. If the outside pad is worn more, it could be the semi floating pins not moving freely. Just some food for thought.
jdpete is offline   Reply With Quote
Is anyone having problems with their 2011? DeeDee1202 2010+ Equinox General Forum 9 01-04-2016 11:26 AM
starting problems dan112 2010+ Equinox Maintenance 4 09-25-2015 11:09 PM
Need some help 2011 ac problems Motavated 2010+ Equinox General Forum 2 06-29-2015 10:07 AM
few problems firefitr24 05-09 Equinox Maintenance 4 03-19-2013 11:26 PM
