09 equinox aftermarket head unit need help!!
This is a discussion on 09 equinox aftermarket head unit need help!! within the 05-09 Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
Need help! So I am Installing pioneer avh-280bt into a 2009 Chevy equinox using scosche dbl din kit and scosche ...
Old 10-23-2016, 07:49 PM   #1 (permalink)
09equinox is on a distinguished road
Default 09 equinox aftermarket head unit need help!!
Need help!
So I am Installing pioneer avh-280bt into a 2009 Chevy equinox using scosche dbl din kit and scosche interface kit gm3000 using harness A as per directions and wired per directions. CD player will not power on ( i have hooked it up to alternative power source to verified unit works) when the interface unit(Chimebox) is plugged into the harness the vehicle will not start and throws service vehicle soon message.but when the interface is unplugged the vehicle starts without error but the CD player still won't turn on. Any assistance will help because I've tried everything I could think of and I'm not having much luck online.i even returned the first gm3000 and got a second gm3000 to see if original was faulty.
The only wires going to the interface are constant(yellow),ground(black),illum(orange),acc(r ed),and a pink wire that I believe is data/signal for the chimes.
Any help would be greatly appreciated.
Thank you
09equinox is offline   Reply With Quote
gm3000
RPM's surging at idle after head gasket job rft607 05-09 Equinox Maintenance 5 11-30-2015 02:30 AM
A real head scratcher jdk200 05-09 Equinox Maintenance 4 09-22-2015 03:49 PM
Head Light Question per00002 Exterior Modifications 0 03-11-2013 08:43 PM
I have sirens in my head. Z_Ghost Off-Topic Videos 10 11-04-2011 07:53 PM
Head-Banging School Band Plays Rage Against The Machine dietz4ibanez Off-Topic Videos 3 04-06-2011 09:37 PM
