07 equinox help
This is a discussion on 07 equinox help within the 05-09 Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
I have reciently purchased an 07 equinox with 155,000 miles on it. Runs and drives great, no codes. But it ...
  • 1 Post By Snowbound
Old 05-29-2017, 06:16 PM   #1 (permalink)
Keithpelton101 is on a distinguished road
Default 07 equinox help
I have reciently purchased an 07 equinox with 155,000 miles on it. Runs and drives great, no codes. But it gets hot and I bleeds the coolant and release the trapped air and she cools back off. Bought it like this. It is not leaking any fluid anywhere. Checked oil for coolant, nothing. Coolant levels pretty much stay the same, can't find anywhere how to bleed the system properly, or could it be bad head gasket. It doesn't smoke
Keithpelton101 is offline   Reply With Quote
Old 10-29-2017, 03:03 AM   #2 (permalink)
The Tireman's Avatar
The Tireman is on a distinguished road
Thermostat,, but to bleed just when get warm loosen bleeder valve when no air comes out, when just steady stream of coolant run out it should be done..
The Tireman is offline   Reply With Quote
Old 11-28-2017, 10:59 PM   #3 (permalink)
Snowbound is on a distinguished road
I’m about to get into this in a new post. It might answer some questions if you still have this issue.
Jim
Edit: never mind. Just noticed the post is from May.
The Tireman likes this.
Snowbound is offline   Reply With Quote
Old 12-09-2017, 10:55 PM   #4 (permalink)
I seen some old posts to
antifreeze, coolant, head gasket
