06 Equinox Stalling | P0171
This is a discussion on 06 Equinox Stalling | P0171 within the 05-09 Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
I have a 2006 Equinox 2WD that stalls and produces a P0171 code. To begin, if I drive the vehicle ...
Old 06-20-2017, 12:26 AM   #1 (permalink)
ResonantEcho is on a distinguished road
Angry 06 Equinox Stalling | P0171
To begin, if I drive the vehicle in the morning, there are no issues. The car drives fine and does not stall. If I drive the vehicle during the heat of the afternoon, about 10-15 minutes into the drive, the RPMs drop and surge between 300 - 1,500 rpms, power cutting in and out. Ultimately the engine stalls. I shift into neutral and attempt to start the car., usually the engine will not start the first time, I turn the key off and then back on, the engine starts at a low, rough idle and stalls. Usually by the third attempt it will run, I can shift back into drive and continue for another 2-3 minutes before it happens again.
The local Chevrolet dealership performed a diagnostic and found that the fuel pressure was dropping very low when the engine stalled, they determined it was being caused by a faulty fuel pump and recommended replacement.
Here is what I have done so far:
- Replaced fuel pump/filter/strainer/pressure regulator (all components in the tank)
- Replaced EGR valve
- Replaced canister purge valve solenoid
- Replaced Ignition wires and plugs
- Replaced fuel cap
I've dumped $800 into this issue so far and I'm pulling my hair out. Any suggestions would be greatly appreciated!
ResonantEcho is offline   Reply With Quote
2006, equinox, fuel pressure, p0171, stalling
05 random stalling derekio 05-09 Equinox General Forum 1 07-02-2017 04:34 PM
2011 Equinox Stalling btweymouth1s 2010+ Equinox Maintenance 0 04-19-2016 09:45 AM
2011 equinox stalling issues? Low4x4 2010+ Equinox General Forum 138 04-16-2016 02:04 AM
CEL Stalling and no oil xx1jpt5xx 2010+ Equinox General Forum 1 12-09-2013 11:59 PM
stalling issue valijo 2010+ Equinox General Forum 20 10-05-2011 11:39 AM
