05 Equinox fuel pressure problems
This is a discussion on 05 Equinox fuel pressure problems within the 05-09 Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
When I turn my ignition key to the on position I get around 55 psi for a split second then ...
Old 07-06-2015, 12:53 PM   #1 (permalink)
jdpete is on a distinguished road
Default 05 Equinox fuel pressure problems
When I turn my ignition key to the on position I get around 55 psi for a split second then it drops to zero. Once I get the engine started the pressure is pretty steady at 52-56 psi. I read when I shut the engine off the pressure shouldn't drop no more than 5-8 psi in the first five minutes. As soon as I shut my engine off the pressure immediately drops to zero. This of course explains my starting issues. Any thoughts on what could be causing this problem? Possible faulty fuel pressure regulator?
jdpete is offline   Reply With Quote
Old 09-25-2015, 11:23 PM   #2 (permalink)
I would look into the Fuel pressure regulator first and if that doesn't fix the problem, it might be the fuel pump/sending unit that needs replaced.
@jdpete
2013 Equinox LT Fuel Filter? LurpyGeek The Official "How To:" Section 1 09-15-2015 10:47 PM
High pressure fuel pump bhotz The Official "How To:" Section 1 08-04-2014 12:30 PM
2010 Equinox Fuel Range Accuracy gosche15 2010+ Equinox General Forum 1 10-03-2013 07:47 AM
High Pressure Fuel Pump jsfb6pts Engine & Performance Modifications 5 03-25-2012 04:46 AM
2005 Equinox Fuel Pump Helene74 05-09 Equinox General Forum 35 06-30-2011 10:37 PM
