High pressure fuel pump
This is a discussion on High pressure fuel pump within the The Official "How To:" Section forums, part of the Equinox, Terrain & SRX Knowledge Center category!
I have a 2011 equinox has a 2.4 rough idle at stop lights some hesitation when you take off continues ...
Old 05-23-2014, 02:25 PM   #1 (permalink)
bhotz is on a distinguished road
Default High pressure fuel pump
I have a 2011 equinox has a 2.4 rough idle at stop lights some hesitation when you take off continues to run after you turn the key off but there is no fuel in the oil.
bhotz is offline   Reply With Quote
Old 08-04-2014, 12:30 PM   #2 (permalink)
ThePapaJohn is on a distinguished road
A few things come to mind:
Malfunctioning injector (s)
Incorrect timing (easy check)
Buildup of carbon in the cylinder (pull your spark plugs [one at a time] and a quick peek might reveal)
These are the leading causes these days for gasoline engines to have a "dieseling" problem.
With you having a rough idle and hesitation to boot, sounds like a timing issue. How many miles on it? When were the plugs/wires last changed? (I've lost count on how many times I have come over to someone's house that attempted to DYI a poor man's tuneup - and miss wired - causing this problem....
Update info always appreciated ~ even if you fixed it on your own...
ThePapaJohn
2007 Chevy Equinox LS
Plain base model - Black
ThePapaJohn is offline   Reply With Quote
DAMN YOU GM!!!! (2005-2006 Nox Fuel pump) Lenn 05-09 Equinox General Forum 18 09-30-2018 08:51 AM
' 10 Nox crankcase pressure? XIVRanch 2010+ Equinox General Forum 1 02-25-2014 08:52 AM
High Pressure Fuel Pump jsfb6pts Engine & Performance Modifications 5 03-25-2012 04:46 AM
fuel pump recall? robkluck The Official "How To:" Section 2 03-02-2012 09:18 AM
2005 Equinox Fuel Pump Helene74 05-09 Equinox General Forum 35 06-30-2011 10:37 PM
