Fully Machined Zero Mile 2.4 Engines w Warranty
I rebuild these Ecotec engines here in Las Vegas and decided to post on here to offer options to fellow Equinox and Terrain owners.
The local dealerships charge about $7,800 to replace the 2.4 power plants. The local shops (if willing to do it) charge about $4,000 for a used swap. I rebuild these engines using all GM factory parts. 2010-2017 GMC Terrain 2010-2017 Chevy Equinox 2012-2017 Chevy Captiva Sport 2012-2017 Buick Regal 2012-2017 Buick Verano Polaris Slingshot 2.4 direct injection engine 4 new updated GM pistons Updated piston rings Main bearings Rod bearings Polished crankshaft Block machine honed Refurbished cylinder head (valve job, valve guides, stem seals) 16 new valve lash adjusters (lifters) Front & rear timing sets (guides, gears, tensioners, chains) Water pump Head gasket Rear main seal Front main seal 4 Iridium spark plugs Thermostat Valve cover gasket Timing cover gasket I prefer to install this engine myself to insure proper oil system prime and break-in. I will sell outright though. Prices for all engines vary and depend on tne condition of your core engine. Text me with the issue your core is experiencing. Smoking? Knocking? Hole in block? Seized? Timing issue? |
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
